Official Raceland Coilovers Thread
Old 11-10-2009 | 10:54 PM
  #2321
NYNCTC's Avatar
he has done it twice to his own car i believe...?
Old 11-11-2009 | 03:23 PM
  #2322
getaforknjob's Avatar
I'd help but I'm at least three hours away.
That's a bit too much.
Old 11-11-2009 | 07:52 PM
  #2323
ny450's Avatar
friend of mine is looking into racelands..think im gonna give him the go after reading this thread..appreciate all the good info!
Old 11-12-2009 | 05:02 AM
  #2324
ScionSnowman's Avatar
Yup and great customer service as well! Received my replacement shock a day early! I installed it and everything has worked out perfectly! The blown one had a bad seal or something. The shaft itself had about 1/8" free play.
Old 11-12-2009 | 01:04 PM
  #2325
09crimsontc's Avatar
are these hard to adjust? how and where do u adjust it at?
Old 11-12-2009 | 01:15 PM
  #2326
NYNCTC's Avatar
you can only adjust the height, just so you know. there are two rings at the bottom of the spring. you can move them up or down depending on if you want to raise or drop the car. it isnt easy but not hard. for someone like me (has to be perfect with measurments) it would take about an hour or so until i am happy.
Old 11-12-2009 | 09:31 PM
  #2327
roger that.
Old 11-13-2009 | 05:45 AM
  #2328
09SocalTC's Avatar
was it the driver side? when i go over dips my front driver makes a clunking noise -_-
Old 11-13-2009 | 05:55 AM
  #2329
Jasper Ash's Avatar
To adjust the height... You just have the jack the car up and adjust the two rings at the bottom of the spring, correct?
Old 11-13-2009 | 03:58 PM
  #2330
o8tC's Avatar
yeah
Old 11-14-2009 | 02:09 PM
  #2331
It's pretty easy; just time consuming.
Old 11-14-2009 | 02:24 PM
  #2332
Yes it was the drivers side. And after driving with the new coilover they sent me is starting to make the same noise again. I'm gonna take the new one off and see if It has the same problem as the last.
Old 11-14-2009 | 04:20 PM
  #2333
Maybe they just make noises. Lol.
Old 11-14-2009 | 08:42 PM
  #2334
09SocalTC's Avatar
maybe, i checked all the bolts nothing is loose
Old 11-14-2009 | 09:04 PM
  #2335
ughh idk about this.
Old 11-14-2009 | 09:09 PM
  #2336
engifineer's Avatar
If it makes noises.. there is something wrong. Coilovers, struts, etc dont just "make noise" for no reason.
Make sure nothing interferes with anything when the suspension is compressed.
Make sure everything is tight.
A bad damper can start making a clunking noise as well.
Old 11-14-2009 | 09:12 PM
  #2337
09SocalTC's Avatar
ill take another look at them again
im thinking it might also be my intake...since it has so much play
Old 11-14-2009 | 09:28 PM
  #2338
rosedaleny806's Avatar
I doubt its anything bad. maybe its jus sumthing typical. I've heard of other coilovers do that.
did u guys check ur sway bars?
Old 11-15-2009 | 12:25 AM
  #2339
personally I think its my end link. When you lower the car it seems as if theres a preload on the front sway bar. Ik my end links are a little beat up. I'm going to take the new coilover out and compare it to the old one and see if they both are doing the same thing. If so maybe they had a batch of bad seals going into the front drivers side struts. Hopefully everything will be okay. I hate the noise....
Old 11-15-2009 | 12:34 AM
  #2340
yellowxhoodie's Avatar
considering the price...im sure there were no bad "batches"
prob. just poor design
