Popping while turning?
Yo, yeah, popping noise in the front end is never good. how many miles do you have on it? could even be a tore up bearing because you only usually notice bearings or tyrods while turning, but your probably on track with the strut. take the tires off and check it out, something might just be loose and that's why your getting that sound. Can you feel anything in the steering wheel or through the gas pedal?
A couple of the previous posts in this thread I would say are in the ball park of some of the things/areas to check. Here's my 2 cents for what it's worth... 1. Verify that there isn't anything physically in the turning path of the wheel/tire. 2. Visually inspect each of the 4 axle boots. (inner & outer) Look for ANY tares or broken/missing clamps. It's most common to happen at the outer CV joint point, but inners can sustain sometimes damage too. 3. If you are lowered (especially if using lower springs over OEM shocks/struts). Verify the springs are still seated properly where they should be. It is common for one to move out of position even with just normal driving. The OEM shocks/struts can extend further then the now shorter springs can which can cause them to move if that happens. It is possible for the root cause to be somewhere else in the steering linkage, but far less common on a newer car unless it has sustained physical damage or if a part had a pre-existing physical flaw in it. Hope that helps ya out.
its the axle im sure its happened to me before but then again my car sits about about 2,5-3.5 inch or so from the ground. what i did is jack the car up and see if you have alot of play in the axle and also check the inside of your rim for axle grease? my front left rim is caked in grease from 4 dif axles messing up. you can got to the auto parts store and and get a replacement axle from there and they have a life time warranty so if it messes up again just take it back and replace it for free.
ight guys let me throw this one at u...i got ran off the road the other day and hit a huge pot hole...now it vibrates really bad which i kno that thats from i have bent rims on the passenger side yayay...but anyway i have a poping sounds in my front end as well...if im setting still in a parking lot or driveway or anything like that and hold the brakes and turn my wheels anyway left or right all the way it pops and cracks and both the passenger and driver side wheel shakes while doing this as well...but if i dont hold the brake and turn it it doesnt do this...also going into a rough curve with a bump in it or something it will pop as well....please help me with this one guys i need this fixed fast its my only ride to get back and forth to work...thank you
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
SpaceCaptain
05-11-2015 06:24 PM
cid_mcdp
01-05-2015 02:45 PM
