Problem with TEIN basics...please help!
I am running TEIN basic coilovers. Right now, the rear sits higher than the front on my car so me and my buddy attempted to drop the rear a little to match the front. TEIN coilovers have 2 collars (one to lock and one to adjust). I was able to get one side done, but I couldn't get the second one to unlock. I haven't adjusted in a while. Darn thing wouldn't budge. I even sprayed it down with JB80. Anyhow to make a long story short. I snapped one of the TEIN adjustment wrenches in half trying to turn the collar. Now I only have one wrench and I can't adjust my suspension. What do I do?
you might be able to relieve some tension by removing the coilover entirely. I just adjusted mine and my buddy strained back muscles getting them loose. I'd ask Tein if they had any tricks.
damn yo that sucks! uhm same crap happened to my tein basic coilvers. i spent hours trying to budge the thing. i took out the whole coilover from the car and thought it'll relieve some tension but that didnt help.
i sprayed wd40 on it and it still didnt work.
So i got fed up and took it to a shop my friend recommended. He sprayed wd40 and let it set in for a while. Then he attempted to crank it. He kept pulling on it and never gave up. He knew exactly which way to pull (whether to loosen it or tightening it), and eventually it began to loosen up.
My advice is to spray some wd40 and let it set in for a good minute or so. Then use the wrench to either tightening it or loosening it ( i forget which way lowers it or raises it). But yeah, its tough...those wrenches hurt like a mother *bleep* but dont give up! if you do...take it to a local shop and hopefully they have stronger and rougher hands to match that metal wrench.
Goodluck
Goodluck
Originally Posted by 05FMtC
use a pipe over the wrench for extra leverage and make sure that you are undoing them and not tightening them.
Originally Posted by tc913
I had this problem too but just sprayed some WD40 and poof, turned like a beauty.
jdlong
05-17-2018 05:20 PM
TheTripleC
01-04-2015 06:46 PM
fluxingnation
12-26-2014 04:28 PM
