Quaife ATB Differential
Old 02-03-2006, 01:55 AM
TheQuietThings's Avatar
Originally Posted by yamaha16bw
If you check out ZPI's website you will see where they are already working ont a 6-speed for the tC.
i believe that they are, but that is going to cost some big bucks.
TheQuietThings is offline
Old 02-03-2006, 02:17 AM
tC_Brett's Avatar
Here's a good site to visit if someone wants to know how a differential works.
http://auto.howstuffworks.com/differential.htm
Also, a spider gear dosen't change gear ratio either. All a spider gear does is help to change the speed of one of the wheels. In order to change the 5th gear ratio, you would need to change the 5th speed gear. You would have to find one made for the same transmission as the tC.
Does anyone know what other toyota vehicles use the tC manual trans?
tC_Brett is offline
Old 02-03-2006, 03:22 AM
io333's Avatar
The "just change out 5th gear" idea is pretty appealing to me, although I think 1st is too low anyway. I just want to go the cheapest route. My #1 concern is to get the tach down about 800 rpm when highway crusing. Acceleration/LSD/etc are all secondary to me. I'd also love to keep the factory warranty when doing it -- say, for example if a dealer could get the different 5th gear and change it out for $750 or so.
io333 is offline
Old 02-03-2006, 04:36 PM
canibusx's Avatar
Say i get the supercharger... will it be easy to break the tires loose with 200hp? I plan on getting headers, pulley and other stuff. Actually i should probably order my car first...
Why did this get moved to N/A forum?
canibusx is offline
Old 02-03-2006, 05:58 PM
youll break lose in every gear except 4th from what ive heard. 1st is a joke, 2nd youll still peel, and 3rd youll chirp.
The discussion here about replacing gears for speed is NA talk. would you like me to move it to suspension and handeling?
Old 02-03-2006, 06:07 PM
canibusx's Avatar
I'd say put it in suspension/handling. As soon as i get my check tuesday i'm heading up to the dealer and order my car, by the time i get it i may have enough for the supercharger. I can only hope Quaife will make a good diff. for this car. This will be my first decent horsepowered FWD car. I've always had posi rear ended v8s.
canibusx is offline
Old 02-03-2006, 06:09 PM
okey doke moving to suspension
Old 03-22-2006, 07:54 PM
moots13181's Avatar
Default timeline and pricing from the "horse's mouth"
Hello,
We are producing a differential for the TC, E350 gearbox.
The part number is 94.309.180.
Cost is $1,295.00 each.
Availability will be first week in May.
Due to is popularity, if you will need one from our first batch, I recomend
that you send your PO as soon as possible, as we have had already many
inquiries.
Sincerely.
Rafael Santiago.
Quaife America.
Hope this helps.
moots13181 is offline
Old 03-22-2006, 07:56 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
ScionBandit's Avatar
ScionBandit is offline
Old 03-23-2006, 04:05 AM
io333's Avatar
Wow. Same gear ratio I assume, or are there options?
io333 is offline
Old 03-23-2006, 11:15 AM
sIcKsCiOnS
DelMarVa
Scion Tuners
yup, that quote hes got is correct
got that same reply from them.....ordering a few sets for my dealer to stock
Old 03-23-2006, 02:25 PM
terra_tC's Avatar
tighttt
terra_tC is offline
Old 03-24-2006, 12:47 AM
nodsetse's Avatar
The LSD does not affect your ratios, these are completely separate aspects of the tranny.
nodsetse is offline
paul_dezod
155
10-16-2006 02:10 AM
dex
06-25-2006 05:21 PM
TimmyT
10
06-08-2006 08:13 PM
GoSwim
24
07-28-2005 09:30 PM
Quick Reply: Quaife ATB Differential
