softest springs
well i want a lower stance but all the springs have a really stiff spring rate for cornering and i was just looking for something a bit softer but i guess im just going with s-techs
can't beat s-techs for what? lowering your car to the point that you actually make your handling WORSE?
i don't think ride height is going to have a huge effect on your 1/4 mile times. better tires, stronger clutch, lsd, forced induction. that is where you want to go for better times.
yeah i was hoping for a spring that would rid the wheel hop from a hard launch and put the power on the ground i probably just need to break down and get some radials on my drag rims
springs dont really come into play for wheel hop i believe, at leats if it does, the difference will be tiny. the most you can do to get rid of them are get new motor mounts or just bolt on a etd.
yeah i was thinking about an edt, does it really make s difference though? Springs probably wont help that much now that i think about it. Im used to a RWD car where a drag spring will take a couple tenths off.
and the LSD will help a lot since both tires will get even power you will be able to tach the engine up higher and put more of the power to the ground
Naughtygoose
07-06-2015 09:59 PM
