tC Front Brake Rotor Diameter?
Anyone that has downloaded the info on the tC or if anyone knows what the diameter of the front brakes rotors are on the tC? The reason why I ask is because I have a caliper relocater kit on my 99 V6 Camry which allows me to use Supra TT front rotors which are almost 13".
And I was just wondering if I could swap my caliper relocater brackets onto this car and have larger front rotors. And if they are different diameters do they use the same size calipers as a 97-01 V6 Camry? I know it's a lot to ask but maybe someone knows.
Thanks...
Thanks...
FRONT:
Pad Area cm2 (in.2) 39.9 (6.18 )
Rotor Size (D × T)* mm (in.) 275 × 25 (10.83 × 0.98 )
Wheel Cylinder Dia. mm (in.) 57.22 (2.25)
Pad Material PS558H
REAR:
Pad Area cm2 (in.2) 20 (3.1)
Rotor Size (D × T)* mm (in.) 269 × 9 (10.59 × 0.35)
Wheel Cylinder Dia. mm (in.) 34.93 (1.38 )
Pad Material PS549
There you go
-Emo
Pad Material PS558H
REAR:
Pad Material PS549
There you go
-Emo
evolving_machine
10-21-2023 01:16 PM
TheTripleC
01-04-2015 06:46 PM
