Tein coilover owners - loud creaking sound in the rear???
Team Hamster
Anyone else with Tein SSP have any trouble with creaking from the rear coilovers?
Mine seem to do it most first thing in the morning for a couple blocks at stop and go even on flat roads. It’s not the frame or unibody either, it’s definitely the coilovers.
I plan on taking time to check and retighten everything this weekend, I was just wondering if this was typical.
...I vaguely remember reading somewhere at some point about someone complaining about the noise their Tein coilovers made.
tia!
tia!
i don't think your problem has anything to do with the coilovers themselves. most likely its a screw/bolt that has become slightly loose. it happens to people with regular aftermarket springs also. i tighten some of the bolts all around and the sound dissappeared.
Team Hamster
I hit all the strut mount nuts with my impact wrench and reset all the dampers (6 turns from full stiff in front and 7 in the rear), there's still a little creak over some speed bumps but way WAY less than before.
Team Hamster
The sway bar bushings? This is a creaking from minor tortional movement the sway bushings would squeak with uniform verticle movement as well as tortional.
...none the less its a good idea and I'm gonna relube them with marine grade lithium grease asap.
Mine squeaks a little in bumps and dips.. I think its the coilover though, I noticed it right after I had mine installed and tested. And my sway is just about 2 mos old and its lubed well.. Hmm. what part of the coilover does it come from?
TheTripleC
01-04-2015 06:46 PM
fluxingnation
12-26-2014 04:28 PM
kagero79
39
11-23-2003 05:26 PM
