tein htech ?s
Old 08-31-2006 | 06:57 PM
release2063's Avatar
Default tein htech ?s
anyone have problems with the htech and which one is better koni or trd struts
Old 08-31-2006 | 07:06 PM
brian's Avatar
koni for damper adjustability
Old 08-31-2006 | 07:12 PM
ElChupacabra's Avatar
Go with Konis. They are way better than the TRDs and I think they might be cheaper. Im a huge fan of the H-Techs but hey, thats just my opinion. I would call them a medium drop...
Old 08-31-2006 | 11:35 PM
i liked the h techs because alot of people said they werent to low and i wasnt going for the low rider i was going for a better look and stiffness and they seemed to do the trick so far but i want it a little stiffer but im not sure about the sway bars because so many people have them coming loose and i dont want to have to put up with that
Old 09-01-2006 | 12:27 AM
BuddhasTC's Avatar
you won't get stiffness out of the H-techs, but you also will have no problem with rubbing or much scraping depending on ur driving. Personally i would go with the Koni's because you can change ur damper settings and make it stiffer if u like
Old 09-01-2006 | 12:37 AM
coil overs are over kill i just want something that is stiff, looks good ,rides good, and doesnt rub
Old 09-01-2006 | 04:22 AM
brian's Avatar
Your final cost will be in coilover terriroty. Tein basics are around $750ish, you'll be spending $600+ on springs/shocks.
Old 09-01-2006 | 07:43 AM
havoc's Avatar
looking back on it, i should have gone with the h-tech or trd instead of the s-tech.
Old 09-01-2006 | 07:52 AM
jd74's Avatar
i have had my h techs in for about 3 weeks and love them. I think it rides better than stock. the drop is suttle and could maybe be a litter lower in the rear. if you want a good look and almost no loss in ride quality get the h techs.
Old 09-01-2006 | 05:50 PM
BLUEMEANIE's Avatar
Team Hamster
I love my h-techs ... could be maybe a half to 3/4 inch lower all around tho. I also have the trd sway bar on track setting and its still a lil weak for my taste. I will be stepping up the the hotchkis bar set asap.
I drove +/-2600mi with a full trunk and 3 guys (St. Louis, MO to Toronto, Canada and back) a week and a half after I put them and the sway bar on and I had no troubles what so ever.
Old 01-31-2007 | 05:28 AM
gicode0823's Avatar
are they low ? im thinkin bout to buy one
hows the handling and stuff good ?
Old 01-31-2007 | 06:03 AM
fsan619's Avatar
I just installed S-techs and personally, I do not think that they even bring the car down that low.... I was like, WTF I can still drive over my curb without scraping..... but the ride if F'n nice. Springs have good stiffniss around the bends and on the road they are a better ride than stock.....
[/img]
Old 01-31-2007 | 01:47 PM
Tcguy85's Avatar
they should still settle a little bit. how long ago did u put them in?
Old 01-31-2007 | 02:40 PM
fsan619's Avatar
about a week ago... I just thought it was a little odd.... Love the ride though...
Old 01-31-2007 | 03:13 PM
Tcguy85's Avatar
i've had my hotchkis springs in my car for almost a month now and it's still a bit higher than most peoples look in their pics but it's been cold here obviously since it's winter. and everybody knows everything get's stiffer in the cold.
Old 02-14-2007 | 03:17 PM
htechs are for 18" rims and s techs are for 17" rims
https://www.scionlife.com/forums/viewtopic.php?t=158970 good write up
Old 08-24-2007 | 10:11 PM
mengsta's Avatar
lol old thread but does anyone know how well/ how long will H-techs last on OEM struts?
Old 08-29-2007 | 05:41 AM
RnB180's Avatar
why do you say that? do they rub?
Old 08-31-2007 | 10:12 AM
808tC's Avatar
my htechs are really nice (though I wish it was a little lower in the back) ...the front sits nice
as for the ride, i think there is no difference from stock LITERALLY (im on stock shocks)
and i like it because it makes the car look better, handle better, w/o having to scrape all over the place...im still able to go over speed bumps without snaking it..
Old 09-01-2007 | 02:36 AM
CricketC's Avatar
depends on where you live and how rough the road conditions are. but i know that some folks can go 20,000 miles or more lowered with stock shocks/struts.
Quick Reply: tein htech ?s
