Tein Install help
Old 05-13-2005 | 09:24 PM
TruTriNiPlaYa's Avatar
Default Tein Install help
i got my tein s techs a week ago and didn't have ne time to throw dem on yet...tommorow i got a day off so i was wonderin if ne of yall boys had ne tips to make life easier....i was lookin under the hood today and noticed that its gonna be ah pain in the ___ to get to da bolts for the shocks cause its half way covered by da plastic ____ from the wipers....ne ideas?
Old 05-13-2005 | 09:37 PM
tCizzle's Avatar
take the wipers off and the trim thats under them.i also recomend a breaker bar
Old 05-13-2005 | 09:40 PM
TXboxdriver's Avatar
a lift and air tools worked fine for me
you need to raise the front end anyway
and get a good spring compressor, you don't wanna die
the rear is the easiest
unbolt shocks and lift vehicle, springs fall out
Old 05-13-2005 | 09:41 PM
dgHotLava's Avatar
moved...
Old 05-13-2005 | 10:13 PM
was it hard for you guys? and whats the easiest way to take off the plastic covering without breaking any thing?
Old 05-15-2005 | 05:03 AM
PoizentC's Avatar
are you talking about the plastic trim by the wipers? I didn't take out the whole thing. If I remember right, there are 3 clips on each side..2 of them can pop off and there's 1 inside the rubber trip piece..just loosen the plastic trim enough to get to the upper bolts
Old 05-16-2005 | 03:48 PM
TheBlade's Avatar
haha, the fronts took me like 20 mins, the rears...dant dant DA...they'll take you awhile. Let me get home tonight and I'll post a pic of how to align the rear lower strut hole with the upper bolt so you dont have to try to turn the springs while uncompressed on the perch while trying to install.
Old 05-16-2005 | 09:07 PM
TheBlade's Avatar
Okay, this will help. When doing the rears there is a way you need to align the opening for the bottom strut bolt when the spring isnt compressed (didnt want to say 'spring is sprung'). Anyway here is a pic that should help. Just align the opening of the bottom of the strut (I put the bolt sticking out so you could see it) and it aligns with the upper bolt that is farthest inward to the car (toward the trunk)
In this pic it looks like the outside bolt, but this is for the Right Rear strut, so imagine turning the picture around 180 degrees
Old 05-16-2005 | 09:10 PM
TheBlade's Avatar
The S-Techs are a big drop, here's a shot of the difference (there is nearly no pressure on the perch before installation.)
Oh, and USE a spring compressor, it could save your life or prevent a hole in the side of your car if you can aim ;)
Old 05-16-2005 | 10:15 PM
bodjie's Avatar
Pop the cover on the wiper where it connects to the wiper motor and take the nut off so you can take the wiper out.
Next is the black plastic cover, there are small round clips that hold it in place. Just push the center with a nail or something pointy and you should be able to pull out the clip.
It works kinda like a rivet or a wall anchor. If you push the center in, the bulge on the backside dissapears so you can just grab the edge with your fingernails then pull 'til it comes out.
Old 05-18-2005 | 03:13 AM
thanks for da info everyone....especially the pics...really appreciate it....keep checkin me out i got big thangs commin in....after the car is dropped....i'll be puttin over $1000 in music...then comes the engine work
SuBSiN
03-13-2015 04:02 AM
Frustratez
02-26-2015 04:03 PM
TheTripleC
01-04-2015 06:46 PM
fluxingnation
12-26-2014 04:28 PM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: Tein Install help
