Tein S-tech + tC = alignment problems for me
Old 06-03-2005 | 03:26 PM
ib2loud's Avatar
Default Tein S-tech + tC = alignment problems for me
the shop i went to said they couldn't get it aligned because something was bottoming out...this is the first time i've heard this. should i take it to a different shop or is this a common problem
Old 06-03-2005 | 04:48 PM
toastbox's Avatar
did you put the bump stops back in stock, did you trim the bump stops down, or did you leave them out completely?
Old 06-03-2005 | 06:12 PM
ib2loud's Avatar
I trimmed the front, it's aligned just fine, it's the rear that has problems. I didn't trim the bump stops on them or take them out, was I supposed to?
Old 06-03-2005 | 06:58 PM
toastbox's Avatar
honestly, I can't even remember if the rears had bump stops in them....but yes....if you are having issues getting the rears aligned, and you did not trim them, then most likely that is your problem.
Old 06-03-2005 | 08:45 PM
ib2loud's Avatar
yeah the rear has bump stops, they're really small so I didn't trim them...guess I can just take them out
Old 06-03-2005 | 09:21 PM
toastbox's Avatar
You probably don't want to leave them out....you'd risk bottoming out your struts, and possibly blowing them.
I'm just going over this in my mind....the alignment tech said that the fron was no problem, but the rear was unable to be aligned cause something was bottoming out? I might take that some other place...and get a second opinion. If they tell you the same thing, I'd take the bump stops and trim them a tad.
What's got me puzzled tho is this: the bumpstops are designed to prevent bottoming out, and blowing your strut up. I'm wondering if the tech meant that somethign was wrong with your strut, and it was repeatedly hanging on the bump stop, or if he meant that it was actually bottoming out. What kind of place did you take it to?
Old 06-05-2005 | 12:50 AM
Dewmerz's Avatar
moved
Old 06-06-2005 | 10:44 PM
ib2loud's Avatar
the thing bottoming out was a washer on the top of the suspension, sorry I don't know much about these cars yet. Is this a common thing
Old 06-06-2005 | 10:53 PM
toastbox's Avatar
I'm not even sure what they are talking about. That doesnt make sense....how could a non moving part, not internal to the compression of the struts, be bottoming out. I'd say its not very common at all
Old 06-06-2005 | 11:11 PM
ib2loud's Avatar
i guess the washer is an oblong syhape and the side that needs to rotate was hitting something...they didn't seem too keen to foreign cars though
Old 06-06-2005 | 11:21 PM
toastbox's Avatar
that washer is held into place...it shouldnt be rotating at all. If I recall correctly, it's held into place by the retaining bolts.
I'm just glad you ere able to get it fixed
Old 06-07-2005 | 01:56 AM
ib2loud's Avatar
yeah i'm going to take it to a different shop, i just wanted to use these guys because they're right across the street. They were nice enough to check the front and say ti was ok and then didn't charge me anything for that and looking at the rear
Old 06-07-2005 | 07:29 PM
ib2loud's Avatar
ok, after driving a few days with the springs on, i've started hearing a clunk from the back pass suspension on hard bumps. I took it all apart and put it back together and made sure it was all tight. Is this something that the S-tech springs are known for or did i miss something.
Delorean2006
03-29-2015 03:43 AM
Delorean2006
03-26-2015 08:35 AM
eatcrispycreme2
01-30-2015 03:42 AM
kleecker
01-02-2015 08:09 PM
fluxingnation
12-26-2014 04:28 PM
Quick Reply: Tein S-tech + tC = alignment problems for me
