tien htecs with my rims..
Wheels are tork revo black with chrome lip18 x 8 with a +35 offset, 1.75" lip, 5 x 100 bolt pattern, 73.1 hub bore with 54.1 hub centric rings installed
and the tires are Yokohama W4S 225/40/18
will i rub if i get Htechs?!?!?!
nah you should be fine with people in the car,at worst the plaxtic liner in the fender int eh front will rub on big freeway dips but it iwll not hurt anything,I got 40 offset and have never rubbed.
My Yaris has 40 offset and is about 3/4" lower than the tC and it only rubbs if I take a corner really fast and hard,or hit a big dip.....and even then it is on the plastic and the tire......no worries.
Htech is a fairly stiff spring on the tC and does not let it lean very much in corners or rebound to much in dips.
when i installed my Htech drop, sway bars and strut bar i did not cut any bump stops or anything just installed it all and rolled out to get and alignment the front sway bar was a real pain though, actually all of it kind of was lol! but the car drives nice and fine im just trying to figure out the right size tires to buy i have 18x8 et35 wheels still in the boxes. have you installed the drop yet? i do not want to rub should i go with the 225/40/18???
eddiewinslo5
01-29-2006 05:06 PM
ProjectD
06-23-2005 01:49 PM
The_Zeeness
12
06-01-2005 11:43 PM
