TRD Rear Sway Bar
Old 05-03-2005 | 08:00 PM
its_ikon's Avatar
here is the hotchkis information
http://www.hotchkistuning.com/cgi-bi...atalogno=22425
Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets.
Specs:
Front Bar - 15/16" (24mm) - 2 position adjustable
Rear Bar - 1 1/16" (27mm) - 3 position adjustable
% Stiffer Than Stock
Front Bar - 40% / 68%
Rear Bar - 273% / 304% / 338%
Retail price: $328.95
Old 05-03-2005 | 08:03 PM
sciontc2005's Avatar
i want a great deal on the rear sway bar and springs for my car, TRD style, anyone know where the best price is? lies?
Old 05-04-2005 | 01:33 AM
chipmOnk's Avatar
Originally Posted by yesti
Originally Posted by chipmOnk
To be honest, I didn't feel any difference with the sway bar alone. Springs on the other hand made a lot of difference.
do you have it on street or race? street won't make that much of a difference. I'm hoping you weren't looking for it to 'stiffen the ride' or something...
Originally Posted by Sparks Scion TRD Parts
The TRD rear sway bar will make a difference especially if you lower it too.
won't stiffening up the springs take movement away from the sway bar? in other words, you are probably feeling the springs more so than the sway bar if used in conjunction. and it depends on what 'difference' you are talking about too...
I have it on race mode (the inner hole).
Old 05-04-2005 | 03:27 AM
yesti's Avatar
you shouldn't feel it too much except when the sides of the car are going in opposite directions from each other. i know street doesn't feel any difference at all...that's what mine is set to. maybe you have to go hotchkis?
Old 05-05-2005 | 05:48 AM
TCRS1_0's Avatar
Ok I am kinda new at this and just got my TC not to long ago , like a few days ago <G> . One thing I noticed about the car was in cornering the front likes to go where it wants to . But I noticed the rear end likes to lean into the corners like its on a delay from the front end . Yeah I am a Newbee when it comes to terms in this catagory . I have thought about the TRD sway bar kit , only cuz I figured it might correct this somewhat . I know springs would fix this issue but since I just got it I am more open to putting a sway bar in then taking springs and struts out . Would the TRD bar or Hot . kit atleast tone down how the rear end reacts in corners ?
Old 05-05-2005 | 05:56 AM
KAOS29's Avatar
i bought it with the springs... the TRD sping and sway bar from mcgeorge.. i can fee the diff most def...
Old 05-05-2005 | 09:17 PM
yesti's Avatar
Originally Posted by TCRS1.0
One thing I noticed about the car was in cornering the front likes to go where it wants to . But I noticed the rear end likes to lean into the corners like its on a delay from the front end . I have thought about the TRD sway bar kit , only cuz I figured it might correct this somewhat . I know springs would fix this issue but since I just got it I am more open to putting a sway bar in then taking springs and struts out . Would the TRD bar or Hot . kit atleast tone down how the rear end reacts in corners ?
in stock form the tC has moderate body roll, but that is not necessarily a bad thing. if you don't like it then sway bars will lessen it. if the front bothers you then only hotchkis makes a front bar afaik. and the front is kind of a pita to change if you diy.
Old 05-05-2005 | 09:25 PM
TCRS1_0's Avatar
its just the rear end I dont like doing that so I will probably be lookin at TRD or Hotchkis . Is it possible to get the rear Hotchkis bar instead of just the set ?
Old 05-06-2005 | 11:57 AM
mcgeorgeparts's Avatar
We have both the TRD and Hotchkis in stock ready to ship at www.mcgeorgeparts.com
Old 05-06-2005 | 08:13 PM
yesti's Avatar
the hotchkis rear bar is kinda extreme by itself, you will GUARANTEED go on rides if you just put that bugger in. having said that (i feel like paula) i don't think they sell it separately so maybe you can test drive a car with the trd and see if it suits your needs...if you can find one ;P
Old 05-06-2005 | 08:38 PM
niksmr2's Avatar
You can get the Progress rear bar. It's 22 mm, although I'm not sure how stiff it is over stock.
Old 05-07-2005 | 01:03 AM
txjcb's Avatar
Default $100.00
http://www.scioncrazy.com/
$100.00
Old 08-15-2005 | 12:28 AM
scionish's Avatar
ok, i'ma newb at this sorta thing... so, stiffer the better for street too? and i was reading hotchkis' installation manual and got me wondering about that... and is front one neccessary? i think it handles well enough no?
Old 08-15-2005 | 01:38 AM
sensay's Avatar
i just wanna know how the rear progress sway bar performs
Old 08-15-2005 | 02:02 AM
B1uEsC1uEs's Avatar
drive in an empty road, go at a good slow speed but not really slow (about 20 - 25 mph) then move ur car left to right with the steering wheel. not that much just a little. and tell me if u feel ur car tilting a little. to eliminate that, sway bars remove body roll which is good for better handling and turns. i ordered my hotchkis sways but our installation failed. the screws were torqued in too much .
Old 08-15-2005 | 03:19 AM
scionish's Avatar
let's say i order this thing online... where can i get it installed?
Old 08-15-2005 | 04:06 AM
daggerSLADE's Avatar
anyone ever hear of the Progress Rear Swaybar .. its 3 way adjustable .. i love the thing .. i have it on the middle setting .. they are selling at http://www.Dezod.com for $165 .. im impressed with mine .. TRD and Hotchkis arent the only ones that have rear swaybars for the tC
hayalex6's Avatar
You do it yourself. If you don't have a jack, just buy some ramps that you drive onto. Get those at Advance autoparts or some store like that.
Always install something easy like a sway bar yourself, you'll end up saving a ton of $$.
Old 08-15-2005 | 07:22 PM
lyrictenor1's Avatar
B1uEsC1uEs:
your install failed b/c the bolts from the stock bar were torqued too tightly and couldn't get them off, or was it because you torqued the bolts on the new bar too much?
i'm assuming it's the former, but i'm just curious...
Old 08-15-2005 | 10:10 PM
B1uEsC1uEs's Avatar
Originally Posted by lyrictenor1
B1uEsC1uEs:
heres the forum to where it explains the installation on m hotchkis sways.
Quick Reply: TRD Rear Sway Bar
