TRD Struts & Lowering Springs
Okay, so I've been doing my research over the past few days (here on scionlife) and I am most likely going to be upgrading to TRD Struts & Lowering Springs, however there are two things I want to be clear on...
1) I've seen people comment that you should wait a "little while" after installing lowering springs to get an alignement so the springs can "settle in." Is this true? (If so how long and how is this not bad for the tires??)
2) Regardless of when I would get the alignment, is it a 4 wheel alignment that is necessay or just the fronts?
I'm not a noob to modifying cars but I've never dealt with this issue (lowering) before so forgive the questions if they seem obvious but I want to make sure that I know what i'm talking about when I take the car, eventually, to have everything put on.
Also depends how much driving you do. I do about 450 miles a week, which would be more than enough to let them settle. And yes, you definitely want a "four wheel alignment".
Scion0814
Scion xB 2nd-Gen Wheel & Tire
02-12-2015 01:41 AM
