Turning issue (Metal popping noise)
Old 12-10-2009 | 11:29 PM
Bacon's Avatar
Default Turning issue (Metal popping noise)
I've done some searching on the forums, and wasn't quite able to find the exact problem in another post, so I decided to create a thread for some insightful input as to my problem.
I recently purchased an all-stock '08 Scion tC from a dealer last week. I've noticed (no doubt, after purchasing the car) that when I turn on the car and make a sharp turn slowly I hear a pop/klacking sound from the front.
After the first "klack" it no longer occurs during the duration of the drive. However, when I put it in park and turn off the car and go for another drive, the one-time klack returns.
Maybe it is my imagination, but it seems that after I get a klack, my car seems to accelerate better.
Now, the noise is more noticeable when I turn harder into a reverse, and it concerns me somewhat as I feel something is going to snap nor or in the future.
Wondering if someone could give some insight into this. I'm not a mechanic, but I do have a college degree, so giving me some technical terms means looking it up online, which I don't mind doing (after all, thats all college kids do now right?)
Thanks.
Old 12-10-2009 | 11:46 PM
DJ08tC's Avatar
sounds like it might be a cv joint since it does it when you are turning.
Old 12-10-2009 | 11:53 PM
sw09's Avatar
a CV joint would make that sound whenever the car is turning not just on hard turns. it seems like there is something loose. do you pull to any direction while driving strait or braking?
Old 12-10-2009 | 11:57 PM
DJ08tC's Avatar
actually no, i have had a cv joint fail on my old car and it only made noise when i turned hard, so it is possible.
Old 12-11-2009 | 12:49 AM
Perroski's Avatar
yea it can be a cv joint, get under the car and check the ruber cover that is right behind the wheel from the inside to check if its somehow cut or broken in any way, if it is, broken cv joints are probably the cause of the problem.
Old 12-11-2009 | 01:13 AM
Bacon's Avatar
In response, yes my car pulls slightly to the left. After it pops, it doesn't do it as much.
For the big question, my car is still under warranty, does it cover this?
Old 12-11-2009 | 01:17 AM
gorbasho's Avatar
Loose lugnuts made mine clack when I turned, I guess from the wheel shifting around.
silly and probably not your cause but just thought I'd throw it out there haha
Old 12-11-2009 | 01:51 AM
Bacon's Avatar
Good advice here...lets see what the dealership says.
Old 12-11-2009 | 05:20 AM
BZinn1's Avatar
front sway bar could be loose....f you just bought it take into dealership and see if they can find it.......but first take a look at CV,sway,wheel lugs and for anything loose on the struts.
Old 12-16-2009 | 10:14 PM
xdejablu3x's Avatar
i recently found out my rear sway bar was loose and made a loud thud sound when making left corners hard or driving up steep directions left.
Old 12-17-2009 | 12:14 AM
Bacon's Avatar
Took it into the dealer, it was the left control arm and right lower ball joint. Whatever the previous scheister owner did to the car, I dislike him, to a degree.
Oh by the way, no cost to me...LOVE the bumper to bumper. I need to find more things wrong with it...
Old 12-17-2009 | 02:40 PM
DezodDon's Avatar
I was going to say ball joints. Very common on civics etc. Sounds the same.
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
setpol
02-17-2015 11:33 PM
XDC
02-01-2015 11:56 PM
cid_mcdp
01-05-2015 02:45 PM
TheRedBox
10-21-2003 09:47 PM
Quick Reply: Turning issue (Metal popping noise)
