uneven drop
uneven drop
i just installed lowering spring for my tc, but the wheel gap on the right side (passenger) is bigger than the left side (both front and rear wheel). does this happen to anyone else? how do you fix it? what should i look for?
this shouldn't happen!! did u install the springs?? i would take off your bad one and make sure your spring is put in right...i did mine with no problems at all....good luck!
What Springs did you install? After I had my TRD Springs installed, I had the same problem. It eventually went away. Now the difference is only millimeters off. Probably due to me being the only person in my tC.
make sure you are parked on a lever surface, b/c the same thing happened to me....I also notice the same thing as you did, I thought something was wrong, it turned out my drive way not level.
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
ScionLife Editor
09-24-2015 10:50 PM
