whenever i go over speedbumps i hear this painful sound
Old 12-15-2005 | 03:32 AM
tcva's Avatar
Default whenever i go over speedbumps i hear this painful sound
whenever i go over speedbumps.. the front suspension/wheels make a creaking sound as it hits the bump.
i just heard it today.
It doesn't happen if i go really slow..
what could cause this ?
Old 12-15-2005 | 04:31 AM
Sam_J84's Avatar
maybe ur strut. check the rubber piece around your strut. could be caught on something. something similar happened to me.
Old 12-15-2005 | 03:20 PM
trdsparks's Avatar
Is that car lowered? If it is them the springs probably haven't settle fully yet.
Old 12-15-2005 | 08:43 PM
ScionNick's Avatar
Are you using Coil Over's or Lowering Springs? Cause Coil Overs do squeek/creek when they are compressed hard
Old 12-23-2005 | 03:52 AM
tcva's Avatar
how do i know if i have coil overs ?
i bought this car used so i'm not sure what the previous owner had done to it.
Old 12-23-2005 | 02:16 PM
CELL's Avatar
Ask him/her
Old 12-23-2005 | 06:26 PM
DuMa's Avatar
tkae off one of the front wheels. the strut is right there. if its black, then its the stock strut. if its red, then its the trd strut. if its green or silver its one of the coiloversystem.
if its pink, man you had a weird previous owner!!!!!!!1
Old 12-27-2005 | 10:46 AM
tikbhoy's Avatar
or
or
or
measure the length from the center of the wheel to the fender
*im at work, i got too much time to waste
Old 12-27-2005 | 01:11 PM
mattssi's Avatar
I hear the same awful sound. Only if I get both rear wheesl over it at the same time. I figured it was the rear sway.
I have the trd springs and trd rear sway
Old 12-28-2005 | 03:38 AM
tcva's Avatar
wow.. so someone else is experiencing this too.
and another thing is it happens from time to time and not every single speedbump.
Old 12-28-2005 | 06:44 PM
ScionNick's Avatar
The reason why I asked is because with coil overs you can sometimes here the spring creeking/turning in the shock tower. Its just part of the natur of coil overs. However you can buy silencers that help out alot. Most suspension companies have them avail.
Old 12-29-2005 | 03:27 AM
tcva's Avatar
it's a stock black strut.
can a stock strut cause that creaking sound too ?
Old 12-29-2005 | 03:53 AM
CELL's Avatar
Does it have sway bars?
I have the hotchkis and my dealer's tech blamed it on the bushings needing greased...but yet, didnt grease them for me like I asked
Old 01-04-2006 | 06:32 PM
hunterUnknown's Avatar
i had the same sound its the fact that it couldbe REALLY cold outside. thats what did it for me.
so before you take any drastic measures like changing anything or greasing anything, just take that into consideration!
Old 01-04-2006 | 07:36 PM
TheScionicMan's Avatar
A common issue on the xB's is that many aftermarket springs will rub on the bottom seat. The OEM springs have a plastic sheathing over them that eliminates the metal to metal rubbing. We took the sheathing off the OEMs and put it on my GoldLines and no more grinding over speedbumps.
I'm not sure if it is the same with the tC, but I bet it is. Anyone have a set of OEM springs around that they can check?
Old 01-04-2006 | 07:52 PM
SquallLHeart's Avatar
uhh.. didn't see any plastic on the stock springs.... i know what you're talking about though.
Old 01-05-2006 | 02:33 AM
tcva's Avatar
it keeps happening..
it only happens when i pass the bump with my front wheel.
Shuold i take it to the dealer ?
Old 01-05-2006 | 03:07 AM
designone's Avatar
I had a noise that only occured when I went over rough roads and speed bumps. I took my car to the dealer today and they fixed it. It turned out that a spot weld had came loose. They had to take off my rear quarter panel to get to it.....but they fixed it.
toyosg
Scion tC 2G ICE & Interior
06-01-2015 08:43 PM
Brimmer555
05-31-2015 02:31 AM
Andreas24
05-17-2015 09:05 AM
corbmonster
01-24-2015 05:22 PM
A1tc2
01-14-2015 02:43 PM
Quick Reply: whenever i go over speedbumps i hear this painful sound
