wierd click when braking and accelerating
Old 10-09-2008 | 10:35 PM
10gxiong's Avatar
Default wierd click when braking and accelerating
hi guys. i had a rotation done about 3 weeks ago. after the rotation, i've been hearing a wierd click coming from the right front wheel. i'm not sure if something's wrong with the suspension or if something's wrong with the brakes. i had stoptech slotted rotors and axxis brake pads installed about 3-4 months ago. the clicking only started after the tire rotation as stated earlier. anyone experience this before? any tips? i'm hoping the guys at the shop are doing anything suspicious.
Old 10-14-2008 | 05:26 AM
atl20ae's Avatar
your brake dust shield may have gotten bent slightly when the wheel was put back on so it could be hitting your rotor. hopefully it's something small like that. check that your lugs are tight too. could be a bad wheel bearing or cv boot though.
Old 10-14-2008 | 05:40 PM
java09's Avatar
worst case.. bearing.. if its a consitant noise.. does the wheel shake at higher speeds?
cv boot if it happens while you are turning.. best way to tell if its that..
as far as after you wheel allignment and it start.. most likely dust shield.. just jump under and check. if touching.. bend that hoe!
Old 10-14-2008 | 05:44 PM
CDogbert's Avatar
Noises under accel and decel are more than likely CV problems.
kmouse64
09-04-2015 01:11 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
07-22-2015 10:13 PM
blackpearlTC
07-19-2015 04:55 PM
rancur3p1c
07-12-2015 07:59 PM
Tak16
07-07-2015 05:45 PM
Quick Reply: wierd click when braking and accelerating
