will tein s tech rub on 225/40/r18
Old 04-21-2010 | 12:16 PM
tcnoob's Avatar
Default will tein s tech rub on 225/40/r18
i got trd rims and i want to put s techs on will i rub
Old 04-21-2010 | 01:49 PM
my06tc's Avatar
im pretty sure they will cause i know people with h techs and 18's and they rub
Old 04-21-2010 | 03:13 PM
fmtc4ever's Avatar
i had s techs with my super 7 and no rubbin at all
Old 04-21-2010 | 03:32 PM
09SocalTC's Avatar
what are the specs on the rims? cant determine if they will rub...only by knowing the diameter.
Old 04-21-2010 | 06:14 PM
tcnoob's Avatar
they are the ones you get from the dealership....the TRDs
Old 04-21-2010 | 07:07 PM
09SocalTC's Avatar
nah you will be fine
Old 04-21-2010 | 07:18 PM
tcnoob's Avatar
ok ty
Old 04-21-2010 | 07:19 PM
09SocalTC's Avatar
yeye np
Old 04-24-2010 | 07:46 AM
tC_andy07's Avatar
i also had the super 7s with stechs. you will get the slightest bit of rubbing on the fender liner but nothing to worry about. it won't hurt anything
Old 04-24-2010 | 07:48 AM
Jasper Ash's Avatar
I don't know, man... he might rub. I'm only on 17's and I rub on any mid-sized dips at +40mph. Is it because I'm on an 8" wide wheel at +35? :shrug: I'm not much of an expert on fitments yet, but I think he might rub on some dips.
Old 04-24-2010 | 07:50 AM
DJ08tC's Avatar
if he rubs it is only going to be a little bit and wont hurt anything. the TRD wheels have the same specs as the enkei super 7s so he will be fine.
Old 04-24-2010 | 08:10 AM
tC_andy07's Avatar
this
Old 04-24-2010 | 08:38 AM
TwztedtC's Avatar
mine rubbed the driver side front. I have 225/40/18 on an 18x8 rim
Old 04-24-2010 | 08:37 PM
TooCool_07's Avatar
you'll be fine. like others said, you will get slight rub but usually only when you make fast tight turns.
im sitting on 18x7.5 with stock offset and h-techs. thats the only time i rub. and its only on the fender lining.
you're on stock offset if the trd are the same as super 7. if you go with aftermarket rims and go with offsets that set flush with the fender then you gotta worry about the edge of the fender cutting into the tire. in that case roll your fender. in extreme cases you gotta pull your fenders out.
yupinmytC
22
07-27-2024 07:08 PM
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
Sgtfluffy16
09-30-2015 01:42 PM
terrye
09-26-2015 12:24 AM
Quick Reply: will tein s tech rub on 225/40/r18
