wish me luck
Old 07-09-2009 | 02:00 PM
brandonc08's Avatar
Default wish me luck
Well after calling up shops around here for spring install i decided that 300-400 is not a good deal...at all so me and my friend are gonna go up to his dads shop and install my springs on my 07 tc and his spring on his STI....gonna be a loooooonnnngggg ddaaaayyy
Old 07-09-2009 | 08:09 PM
ack154's Avatar
Take a read through here if you haven't already:
https://www.scionlife.com/forums/viewtopic.php?t=105012
There are some other options for installs at the bottom.
Old 07-09-2009 | 08:47 PM
ScionJim23's Avatar
I installed my JIC coilovers with ease. Took my time (had my girlfriend help as a second hand which came in handy) Took a break midway also. took me most of the day but was worth it.
Old 07-09-2009 | 11:52 PM
brandonc08's Avatar
WHOOO!!! they're done and look amazing but like a lot of people i've read about im getting this bad knocking sound when i hit small bumps...passenger side from wheel sounds like where its at...will an alignment fix it or did i *** it up?
Old 07-09-2009 | 11:55 PM
ack154's Avatar
Knocking sound is either loose nuts on the top of the strut or sway bar connections. Most common anyway.
Old 07-10-2009 | 12:53 AM
ScionJim23's Avatar
Yes, make sure your nuts are tightened to spec on the strut tower.
Old 07-10-2009 | 01:15 AM
brandonc08's Avatar
ya i read about that and went out to try and tighten them and i don't have a wrench big enough if i take it to get an alignment and what not you think the people will tighten that for me? might get a kind mechanic for once hahahha
i just took pice so ill try and post em if i figure out how
yhwhdesign
06-11-2021 03:34 PM
Rob54Monty
01-20-2016 01:41 PM
BlingSlade
09-05-2015 08:52 AM
Quick Reply: wish me luck
