zinc plated rotors
Old 06-27-2007 | 03:26 AM
mattieg's Avatar
Default zinc plated rotors
I am in the need of some zinc plated, drilled/slotted rotors for my car. Two piece would be awesome, even though I dont really need it. Maybe axxis ultimate pads? I have been getting my car ready for minor road race courses but I know I will be getting into bigger courses later on in my days.
Old 06-27-2007 | 03:55 AM
Yanki01's Avatar
dont know if its zinc or what but their probally the top 3 brands when it comes to brakes....
http://www.dezod.com/cat_brake_rotors.cfm
Old 06-27-2007 | 04:04 AM
mattieg's Avatar
Ya im thinking about calling Joe or Paul from Dezod to see if they can get me the drilled and slotted ones. Im really looking to get zinc plated so they dont rust as easily. Any opinions on pads?
Old 06-27-2007 | 04:10 AM
Yanki01's Avatar
probally the Axxis Ultimate pads....
http://www.dezod.com/cat_brake_pads2.cfm
Old 06-27-2007 | 12:19 PM
MJVsTC's Avatar
I have the Brembos on my car and they are great. A little pricy, but it's worth it. The blanks come from Canada and are drilled/slotted here in the US, so they are less prone to cracking than blanks from overseas where the metal quality is not as high(read: CHINA/JAPAN). Canadian blanks tend to be of higher quality.
If you plan on tracking the car, rethink the drilled aspect of your decision. MANY track cars that have drilled rotors crack them over time. Unless a rotor is actually cast with the holes in place, I would stay away from them (unless it's in DD situations). Two ways of looking at it are: 1) Rotors are a wear and tear item that can be easily replaced or 2) Rotors are a long term investment that you may not want to replace every couple of years. Depending on how you think about it should tell you what kind of rotor you want to buy.
Zinc is a great finish; the rotors will not rust whatsoever. They stay shiny, too. If you see rotors advertised at Cadmium plated, second guess it, because the EPA restricted (not banned) the use of Cadmium in applications such as this.
Also, be careful the pad/rotor combo you buy. Many rotor manufacturers warn that using a race compound pad will severely hurt braking capabilities when using a specific type of rotor. In other words, not all pads and rotors work together.
Take your time and find out what you really NEED as opposed to what you want or what may look good, because that may not be the safest/cost efficient route.
Old 06-28-2007 | 01:43 AM
mattieg's Avatar
Thanks guys. MJ where did you get your rotors from so I can research them more. Im gonna take it one step at a time, getting the rotors first then finding a pad that would accompany the rotor.
Old 06-28-2007 | 01:59 AM
MJVsTC's Avatar
They are on my C5. I never put rotors on my tC, but I got them from TireRack.
Personally, I'd go with some type of slotted rotor to prevent glazing, but in the end it is your call.
Old 06-28-2007 | 02:43 AM
mattieg's Avatar
damn you got me excited cause i didnt know they had brembo rotors for the tc. Well I will still search around.
Old 07-22-2007 | 08:41 PM
tcvenom's Avatar
as for rotors and pads combo will powerslot rotors in combination with ebc greenstuff pads be ok
Old 07-22-2007 | 08:54 PM
davedavetC's Avatar
http://www.dezod.com/pd_brembo_sport...torstc_051.cfm
http://www.dezod.com/pd_brembo_sport_rear_rotorstc.cfm
Old 07-22-2007 | 08:59 PM
tcvenom's Avatar
are powerslot rotors zinc coated or cadmium, because i hear cadmium is bad, or they can be wrong
Old 07-22-2007 | 10:51 PM
mattieg's Avatar
I saw those brembos on dezod but i wanted to have mine drilled and slotted.
Old 07-22-2007 | 10:59 PM
tcvenom's Avatar
at tirerack.com the powerslot slotted rottors state they are Cadmium, but when i contacted ultrarev.com who have a better price, they told me they were zinc ..does anyone know for sure which one it is
Old 07-23-2007 | 12:22 AM
2fast4you's Avatar
Team ScionTific
It probably an interchangeable term.
Cadmium is extracted from Zinc and behave similar in terms of preventing oxidation, however, it has a higher toxicity than zinc.
Old 07-23-2007 | 12:27 AM
tcvenom's Avatar
so is Cadmium ok
Old 07-23-2007 | 12:31 AM
2fast4you's Avatar
Team ScionTific
Originally Posted by tcvenom
so is Cadmium ok
Sure, I just wouldn't make a 60-0 stop, jump out of your car, and inhale the fumes.
Old 07-23-2007 | 12:49 AM
tcvenom's Avatar
thanks
Old 07-23-2007 | 02:01 AM
mattieg's Avatar
why are you choosing powerslot over rotora?
Old 07-23-2007 | 02:30 AM
davedavetC's Avatar
so is Cadmium ok
hahah i litterally LOLed at that... idk why maybe because i was a chem major for a couple years, so i apprieciate chemistry jokes i guess. but i laughed at that.
Old 07-23-2007 | 05:15 AM
tcvenom's Avatar
basically because i dont like the line that rotora offers, powerslot looks much nicer
dougcbx
10-23-2015 11:42 PM
Darrenohooligan
09-26-2015 07:21 AM
Mjdavis1994
09-21-2015 04:42 AM
Subaru86
09-14-2015 12:43 PM
Subaru86
07-31-2015 04:00 AM
Quick Reply: zinc plated rotors
