225/35/19 19x9.5 ! ! ! !
Old 07-21-2007 | 02:31 PM
VIVALI's Avatar
Default 225/35/19 19x9.5 ! ! ! !
Does any one have this wheel and tire configuration?
I would like to see what it looks like on a tc, also if it's on Tein S would there be any rubbing
let me know
thank you very much
oh i tried searching also, no luck, so I'm asking
thanks in advance
Old 07-21-2007 | 02:35 PM
1_kLEan_tC's Avatar
Your are going to rub....i dont think anyone has done 19x19.5. I know 19x8 works with rubbing.....but it depends all on the offset..
Old 07-21-2007 | 03:07 PM
nytlemgr's Avatar
Approved rim widths for that size tire are generally 7.5 - 9.0 inches. In short, mounting those on a 9.5 rim is not a good idea!
Sorry I can actually tell you if they will fit with out rubbing. (Safety is just a tad more important)
Old 07-21-2007 | 05:14 PM
Phlame217's Avatar
I have 19X8 on H-Techs and only rub on bumps and crap
Old 07-21-2007 | 10:05 PM
tC9o9's Avatar
that is way too thin of a tire for 9.5", dont do it regardless if it fits or not
Old 07-21-2007 | 10:18 PM
05FMtC's Avatar
yea even if it fits, your ride quality is going to suck mad ***** and you will probably be very prone to bending your wheels since there will be minimal cushioning from potholes and such.
Old 07-22-2007 | 09:15 PM
VIVALI's Avatar
Thank you all for the advice.
will this configaration work or will it rub
225/35/19 19x8.5 with and offset of 38
thank you in advance
VIVALI's Avatar
Old 07-23-2007 | 03:34 AM
Torcha's Avatar
phlame. what ur offset? and tire size?
Old 07-23-2007 | 04:40 AM
VIVALI's Avatar
offset 38 tire size 225/35/19
Old 07-23-2007 | 10:49 PM
Phlame217's Avatar
Im 40 offset and im on 235/35/19 nitto 555 extremes
Old 07-24-2007 | 03:40 AM
Torcha's Avatar
do u think the same setup would work but with 35 offset and trd drop?
Old 07-24-2007 | 05:23 AM
Phlame217's Avatar
i would yes, because htechs are lower than trd and 40 sits out father than 35
Old 07-24-2007 | 05:37 PM
Torcha's Avatar
35 sits out farther than 40 i thought? cuz on the stock 17s its 45.
Old 07-24-2007 | 05:42 PM
DuMa's Avatar
just use rubber bands for your tires. its pretty much the same thing
Old 07-24-2007 | 05:48 PM
nebster's Avatar
yes it will rub
i am running a 10 wide but my offset is around 47
plus a 225 on a 9.5 would be stupid. no lip protection at all
Old 07-25-2007 | 08:03 PM
deflaytedwayz1's Avatar
i was always a fan of rubber band tires until i got a set..i have 225/35/18 on my truck and it rides like ____..you feel every little bump you didn't even know was in the road...
Old 07-25-2007 | 08:17 PM
2_much_tc's Avatar
i actually run this setup with no issues....
nebster
Scion tC 1G Wheel & Tire
12078
05-06-2014 12:22 AM
Mize
09-09-2007 02:56 AM
dieselstation
08-31-2007 03:36 AM
Griffin4three22
20
04-16-2007 05:52 AM
Griffin4three22
Scion tC 1G Aero & Exterior
67
03-13-2007 12:05 AM
Quick Reply: 225/35/19 19x9.5 ! ! ! !
