5x100 to 5x114 conversion???
Old 11-10-2011 | 07:06 PM
Dankday's Avatar
The wheels im getting are 5x114.3 18x8 +45 all around. I need to know what size adapter to get for the front and back? Could someone let me know?
Old 11-10-2011 | 08:38 PM
yellowxhoodie's Avatar
figure out how flush you want it.
https://www.scionlife.com/forums/sho...d.php?t=142934
then order whatever size you need to achieve desired offset.
Old 11-11-2011 | 04:13 PM
boostedrs1's Avatar
No spacers for this guy! Im not a fan of them but to each its own. So my question is what car has the 5x114 hub we need to press in are bearing? Idc how much they cost I want to do it the right way. Yellow if you know lemme know!
Old 11-11-2011 | 04:40 PM
Dankday's Avatar
Well with the offset of 45mm, and the adapters being 25.4mm or 1 inch. Do I add those together to get the new offset or subtract them to get the new offset. Sorry Im just a little confused.
Old 11-11-2011 | 04:42 PM
45-25. so your offset would be approx +20
Old 11-11-2011 | 04:44 PM
Idk, i was going to mess around with some xB hubs and stuff to see if I could get them to work on the tC because 5x114PCD is way more desirable than 5x100, but I just ended up selling the car.
Old 11-11-2011 | 05:02 PM
Dankday's Avatar
Thank you, so it will hang over the fender by 3mm according to the chart. Does that mean that I will rub or have to do any sort of cutting? Or is this unsafe? If that is the case I can just order a smaller sized adapter.
Old 11-11-2011 | 05:13 PM
Whether it rubs or not depends on your ride height and tire size, you can run stretched tires and a small amount of negative camber and im sure youll be fine. You will prob have to roll your fenders though.
Old 11-11-2011 | 09:21 PM
boostedrs1's Avatar
lol and your still a scionlife ***** haha.. yea i will have to just have napa drop of a xb hub and messure it out. if you come across anything for the hubs lemme know
Renuco612
09-16-2015 09:01 AM
rvascion
Scion xB 2nd-Gen Wheel & Tire
08-16-2015 02:26 AM
SubrinaIsMyCar
03-08-2015 07:53 AM
paul_dezod
Scion tC 1G Wheel & Tire
12-10-2014 06:46 PM
Quick Reply: 5x100 to 5x114 conversion???
