Brakes Squeaking - New Brakepads, Silicon on the Metal Parts
Old 12-26-2006 | 07:14 PM
elecTriC's Avatar
Default Brakes Squeaking - New Brakepads, Silicon on the Metal Parts
So I have replaced the brake pads, and put the "Brake Quieter" on the metal part on the outside of the pads, but its STILL SQUEAKING!!
It's driving me crazy. Has anyone else had this problem?
Old 12-26-2006 | 07:38 PM
Spect2K3's Avatar
That brake quieter compound worked for me. What kind of pads/rotors are you using?
Old 12-26-2006 | 07:45 PM
elecTriC's Avatar
Stock Rotors, 2nd set of pads were purchased from Toyota..
Old 12-26-2006 | 08:47 PM
Yanki01's Avatar
im starting to have "some" squeaking. Only when i first start moving my car tho. Im thinking its just break pads and hope to have some new really soon!
Old 12-26-2006 | 11:43 PM
Spect2K3's Avatar
The two things that i'd suggest are the following:
1) Make sure you followed the bed-in procedure (very important)
2) Make sure your rotors don't need to be resurfaced (if they do, then do it)
Hopefully that'll help. This is of course assuming that everything was installed properly, but the brakes are so easy, i'm sure you did it fine.
Old 12-27-2006 | 12:18 AM
The_Instigator's Avatar
Try this: http://www.stoptech.com/tech_info/wp_bedinstock.shtml
..and let us know what happens.
Old 12-27-2006 | 02:41 AM
-doomed-'s Avatar
also try and get new brake hardware. IE: the metal shims that go on the caliper braket. if those wear out then there will be excess movement.
also how many miles on the rotors... have they ever been resurfaced before?
if not and they have alot of miles on them and become under spec, then they need to be raplaced.
also any grooves in the rotor will cause noise until the pads fully seat in the grooves.
also make shure that the sliders are not stuck/frozen.
also cleanliness is a big factor in brake noise. if your hands are dirty while doing the brakes you should wash them often or invest in some gloves
Old 12-27-2006 | 04:08 AM
elecTriC's Avatar
Thanks for the replys guys.. I'll try it out the next time I get a chance and let you know how it goes!
hampton1100
05-28-2015 08:32 AM
luckypixi
01-28-2015 06:29 PM
