Burning out in 2nd
Old 10-20-2007 | 01:41 AM
Deathwish238's Avatar
Default Burning out in 2nd
Okay, so I'm not quite burning out in second...but if I'm driving hard and shifting quickly, I naturally burn a little in 1st but I almost always screech when I shift into 2nd. Is this because my tires are stock Potenzas? Or does the tC just have a lot of torque?
Old 10-20-2007 | 01:48 AM
InfideL's Avatar
no thats normal it means you shifted fast enough to chirp 2nd
Old 10-20-2007 | 01:51 AM
silverstreaktc's Avatar
it means you came relatively close to power shifting.
Old 10-20-2007 | 04:01 AM
GarmaZed's Avatar
Which is bad.
Old 10-20-2007 | 04:04 AM
fujita_TC's Avatar
its becoz..of ur tires..lol juz kiddin..hell when i used my steelies..i chirp till third...lol
Old 10-20-2007 | 12:44 PM
hmm...well I'm relatively new at driving a manual. I learned on my tC. What am I doing exactly? Shifting too quickly?
Old 10-20-2007 | 02:28 PM
emiller's Avatar
Practice makes perfect. Pretty much you are giving it too much gas and letting the clutch out too fast. Give it a little less gas and let the clutch out a little slower. Don't ride the clutch though and don't bog it by not giving it enough gas. Really it sounds a lot harder than it it. This is where the practice part comes in. Every car is a little different so you need to find the right spot for this car. If you know someone that can drive a stick have them ride with you while you practice and they can give you pointers.
Don't worry the car will be fine as long as you don't make a habit of doing this all the time. The BS tires are pretty crappy which makes it even easier to chirp them.
Old 10-21-2007 | 12:37 AM
Cool...so then when I'm gunning it...
I should shift giving it less glass and then floor it?
Old 10-21-2007 | 01:09 AM
scionman07's Avatar
does this mean when i shift into 4th gear in my camaro and the tires spin like a mother.... and smoke, im shifting to fast?????.....no just kidding guys. if your car is stock its not to good to do cause you are dumping clutch to fast or to much gas. our tc's have just over 160ft. lbs of torque....no power house thats why i have a camaro with ove 500 on the engine and almost 800 on bottle
Old 10-22-2007 | 01:00 PM
SCIONshane's Avatar
Big Sky Scion
yeah just don't dump your clutch as much as you probably are now. and get on it a little easier if you don't want to spin through 1st gear.
Old 10-22-2007 | 01:01 PM
SCIONshane's Avatar
Big Sky Scion
my tires are really slick now and i've spun 3rd in the rain lol.
Old 10-23-2007 | 03:01 AM
WAlterEgo's Avatar
ive chirped in third several times on quick acceleration on dry road
Old 10-23-2007 | 03:05 AM
Which is bad.
indeed
Old 10-23-2007 | 05:06 AM
Thanks for all the replies.
So...what are the long term effects of power shifting? Is this why people upgrade their clutch? So their clutch can take the abuse?
Also, a little off topic but what's the proper RPM to burn out at in 1st?
Old 10-23-2007 | 09:26 PM
Aroddalobster's Avatar
does that mean he's wheel-hopping? cause i heard that that's pretty bad for the axle in the long run
Old 10-23-2007 | 10:14 PM
people upgrade their clutch for abuse. but because their engine has more power than their stock clutch can take. powershifting is horrible with or without an upgraded clutch.
yupinmytC
22
07-27-2024 07:08 PM
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
mudguy
10-22-2015 04:31 PM
Sgtfluffy16
09-30-2015 01:42 PM
interestingmoron
09-16-2015 06:59 PM
Quick Reply: Burning out in 2nd
