How much can new tires affect MPG?
Old 12-23-2007 | 09:33 PM
buster71's Avatar
Default How much can new tires affect MPG?
For the first 64000 miles of its life, my tC rolled on its stock Potenzas, consistently getting between 28.50-30.5 MPG on each fill-up (I'm obsessive about calculating each time).
For the past 3000 miles, I've been on my new set of Cooper Zeon A/S, and I've only been getting between 25.5-27.0 MPG. May not seem like a lot, but it calculates to a possible worseining of fuel mileage by 15%. It's pretty substantial, then.
Can tires affect MPG this much? Assume everything else is the same, such as tire size, vehicle weight, driving style, PSI (I stick to Scion recommendations).
Someone told me it could be the additive the gas companies are required to put in during the cold weather months, but I never had such a decrease in the previous 2 winters.
Old 12-23-2007 | 11:28 PM
emptystreets130's Avatar
how sticky are the tires. The softer the tires are the more traction you'll get. This in turns creates more friction and reduces your MPG.
Old 12-23-2007 | 11:34 PM
djct_watt's Avatar
Team Sushi
The weight of the sidewall and the your tire pressure will also have a significant affect. Wheel/tire modifications have the most effect on MPG than just about any other mod. . . even FI (assuming you stay out of boost).
Old 12-24-2007 | 03:23 AM
WAlterEgo's Avatar
assuming ur still on stock rims, the tires weight and size themselves can have an effect.
Old 12-24-2007 | 08:23 PM
sciontc_mich's Avatar
but 25-27mpg is average/normal for the tC pretty good for the winter. as the gas companies change to a "winter gas" that leads to lower fuel economy for improved starting in cold weather.
i say you're doing fine.
Sooby
Scion tC 1G Wheel & Tire
11
04-08-2020 11:51 PM
Fisqual
09-22-2015 05:51 AM
debris
03-13-2015 08:15 AM
toyotaisme
01-10-2015 10:24 PM
stankubrick
10-16-2003 10:38 AM
Quick Reply: How much can new tires affect MPG?
