hydrolic jack
Old 06-12-2008 | 04:07 PM
GQQSE13's Avatar
Default hydrolic jack
ok this is definately going to sound like a newb question. its about time to rotate the tires, but i definatley dont want to use the damn sissor jacks. where is a good spot to "place" the hydrolic jack to raise up the car that is sturdy?
thanks,
Old 06-12-2008 | 05:16 PM
SF2K4's Avatar
If you look at the tab that you're supposed to put your scissor jack on, I use those 4 points for the jack stands... now, if you follow the metal that the tab is attached to, you'll see it's all there just with some plastic up against it. I believe there are a few more spots where the plastic isn't the same height but either way, I've yet to cause damage so I recommend just jacking the car up anywhere along that metal frame line.
Old 06-13-2008 | 04:59 AM
jurassic1's Avatar
Check the owner's manual, somewhere about rotating tires/placing the jacks...at about 2nd half of the book. It shows if you dont want to raise the car in the four corners, you can place the hydraulic jack in the center portion in the front and rear underneath the car. You will see the jack point as looped metal part sticking out...
You will place the head of the jack there and either raise the whole front or the whole rear.
Old 01-02-2009 | 12:59 AM
geo46_2's Avatar
aweseome i just might go and buy me a hydro jack and jack stands
Old 01-02-2009 | 02:42 AM
nebster's Avatar
if you're super low you wont be able to get to those two spots that jurassic posted so you'll need to roll up on some wood.
Old 01-03-2009 | 02:15 AM
geo46_2's Avatar
i just bought a hydraulic jack and jack stands for 43 bucks at autozone. pretty good deal
Old 01-03-2009 | 02:34 AM
nebster's Avatar
i like my low profile ____ but that was like 120 bucks for just the jack.
Old 01-03-2009 | 02:48 AM
RCZDesigns's Avatar
I'm pretty low and I have a "low profile" floor jack, it's like 4 inches at the lifting plate. 4 inches sounds high but thats only like one finger tall, I can't imagine many cars being much lower than that.
Got it from sears for like 60bucks
Old 01-07-2009 | 07:29 PM
iheartzombies's Avatar
I got a low profile from northertool.com that works well, but a little secret I've learned is that you can remove the wheels on most jacks to get some extra height reduction.
The metal will scrape on the cement but at least you're getting the car off the ground.
Old 01-08-2009 | 02:12 AM
BZinn1's Avatar
I use the frame rail or the center of the rear end to lift from.......try to never use the sissor jack......it will wear you out before you get the car off the ground.
yhwhdesign
06-11-2021 04:34 PM
prescottn
Scion tC 2G ICE & Interior
04-26-2016 02:14 AM
prescottn
10-08-2015 06:31 PM
Scionxa180
09-24-2015 04:40 AM
RokGoblin
Scion tC 1G ICE & Interior
08-11-2015 06:24 PM
Quick Reply: hydrolic jack
