I need help FAST
Old 11-20-2007 | 09:48 PM
tC4italy's Avatar
Default I need help FAST
I'm sitting on TRD drop. I have 18x8 +38 offset. Tire size now is 225/40/18.
I rub.
I want to put the stock rims for winter and I wanted to get the Dunlop M3 winter tires 215/45/17 (which is stock tire size).
That size is out of stock for the rest of the season.
So I have 2 options:
1. Get the Dunlops M3 winter tires in size 215/50/17 BUT I'M AFRAID OF RUBBING. IF I AM RUBBING NOW WITH 40 I DON'T EVEN WANT TO THINK OF 50. UNLESS YOU GUYS TELL ME THAT THE RUBBING WILL GO AWAY SINCE I WILL BE GOING FROM A 18" RIM TO A 17" RIM.
2. Get a different tire, even though I dunno which ones since I was pretty set on the dunlops.
Thank you for the fast response!!!
C>
Old 11-20-2007 | 09:53 PM
2_much_tc's Avatar
you wont rub because the rim is 1 inch shorter. you can do the 215-50-17 but the tire will look huge!
Old 11-20-2007 | 09:55 PM
kiss_kiss_kill's Avatar
Can you do 215/40/17? Is that an option?
Man, it's so weird seeing 50 series. I'm running 315/25/20s on my tC.
Old 11-20-2007 | 09:56 PM
tC4italy's Avatar
eh I rather it look meh and be safe for winter snow n black ice ;)
Old 11-20-2007 | 09:57 PM
tC4italy's Avatar
You guys are in cali....
it's completely different here =/
I doubt winter grip would be good with such a low profile as 40
Old 11-20-2007 | 09:59 PM
tC4italy's Avatar
I just checked. They don't have those tires in a 40.
Old 11-20-2007 | 10:01 PM
kanundrum's Avatar
its a winter tire so it will be in 45 or 50, no such thing as a low profile winter tire. again your rim will be 1 nich less in diameter but ull be .5mm bigger so it should be good.
Old 11-20-2007 | 10:03 PM
Dakine's Avatar
Concept in Motion Crew
haha "C>" Awesome, i would help but no snow here.
tC4italy's Avatar
yeah seee "should" doesn't flow with me and my safety
lol
tCTaco's Avatar
215 is skinny compared to a 225.
40 series on a 18" is about the same as a 45 on a 17" in height.
So if the stock is 215-45-17 and you go to a 215-50...you should be fine....How do you rub with a 225-40-18...I have the same tire size on my RS1 with the S-tech drop and dont have any probs.
Old 11-20-2007 | 10:04 PM
kanundrum's Avatar
in terms of rubbing I meant
Old 11-20-2007 | 10:05 PM
kanundrum's Avatar
if there is weight in the back. its very odd cause i have the trd drop too and I rub, not too sure why.
HR_Guy's Avatar
I would suggest 225/45/17 instead of 215/50/17. It's overall smaller in diameter and you'd have less chances of rubbing. Though your losing an inch in wheel width and going from 38 to 45 offset, so you probably wouldn't rub either way.
Old 11-20-2007 | 10:07 PM
tC4italy's Avatar
what
now im really confused
why are we changing tire width now??
Old 11-20-2007 | 10:09 PM
tC4italy's Avatar
ever since 2 chubby ppl sat in the back
it rubs like a **** when i take dips or when there's weight in the back
so yr saying my 225/40/18 will equal (rubbing issue wise) as 215/45/17
so im screwed.
Old 11-20-2007 | 10:10 PM
kanundrum's Avatar
In the winter your suppose to have thinner tires for less resistance against snow unlike summer tires where wiser is better.
thats why 215/45/17 was OPTION 1, but they are out.
Option 2= 215/50/17
Old 11-20-2007 | 10:11 PM
tC4italy's Avatar
for snow traction is 215 better or 225?
Old 11-20-2007 | 10:13 PM
tCTaco's Avatar
How about 205-50-17
Old 11-20-2007 | 10:16 PM
HR_Guy's Avatar
215 is better since it's skinnier, but a 215/50/17 is bigger in overall diameter and would be more likely to rub than a 225/45/17. 10mm wider is not going to make any noticeable difference in snow. That was why I suggested it. If you're set on a 215 tire, just know the size you put on is over a 3% difference from stock, which is usually not recommended.
Old 11-20-2007 | 10:19 PM
tC4italy's Avatar
I don't get it
Quick Reply: I need help FAST
