Just got new rims..problem
and...for some reason on the highway today...my steering wheel was vibrating quite a bit..and hte mait reqd signal turned on..
the instal was perfect
used a torque wrench to make sure
and they fit the car fine
does anyone know why
Mait light is prolly a oil change. It comes on every 5000 miles. Read how to re set in the manual. You prolly dont have hub rings. if you dont then go get some and have them re balanced.
and it sounds like they did not reset your maintenance lamp.
To do so, Turn your engine off, Hold down your odometer reset, turn engine back on. You will see the odometer start blinking from 5 lines down to 0. Each of those bars represent 1000 Miles before the maint lamp turns on again.
So if you want the lamp to come on at 3k, wait for 3 bars, 5k = 5 bars and so on.
And yes, get your wheels balanced.
^ That sounds about right. They are usually very small but can make enough of a difference to take away the vibration. The fill the space between the hub of your car and the centerbore of the wheel - since they're usually not an exact match.
And yes, they may also need to be balanced.
