lightest and cheapest rims for tC
Old 08-24-2006 | 08:19 PM
JustAtC's Avatar
Default lightest and cheapest rims for tC
Does anyone out there know what the lightest and cheapest rims for tC. I know at one time, the Konig Hellium was best bang for the buck but now I can't find it to fit the Tc.
Old 08-24-2006 | 09:07 PM
chrischoi's Avatar
check the sponsored tc and message c2auto i think.
Old 08-24-2006 | 09:38 PM
The_Instigator's Avatar
15" steelies?
Old 08-24-2006 | 09:47 PM
i007spectre's Avatar
Id like to find some enkei rp03's Anyone seen any good deals anywhere.
Old 08-25-2006 | 03:04 AM
Gunner1's Avatar
How about these...
http://www.edgeracing.com/wheel/2002/
Old 08-28-2006 | 06:02 AM
06fmtc's Avatar
i got enkei rp-02s.. they are only 18 pounds for an 18" wheel and picked them up for 79 each on edge racing
Old 08-28-2006 | 11:36 AM
brownbanana's Avatar
Originally Posted by Gunner1
18.5 lbs for a 17" wheel, def not the lightest. Lighter possibilities would be for a 16" or even 15" wheel. Rota's are light and cheap.
Old 08-28-2006 | 01:03 PM
JustAtC's Avatar
79 /ea is a very good price....even if it's not quite as light as many other rims out there. I like the recommendation.
Old 08-28-2006 | 02:00 PM
krdshrk's Avatar
The Flik Hornets I have (also from EdgeRacing) are 17 pounds each, look great, and aren't that pricey ($89 each right now). The only thing you'll find lighter on their site is the 5Zigen Fn01r-c's, and they're expensive and not much lighter.
Old 08-29-2006 | 01:35 AM
Gunner1's Avatar
15's or 16's on a TC? eww.
A tall modern car like ours w/ a 106" wheelbase makes 17's look plenty small. Anything smaller looks blah.
Remember, that's 18.5 lbs. for 17's that are 8" wide. Good if you're interested in getting the most rubber for the dollar under your TC.
Here's the 17" TC list for edge racing...
http://www.edgeracing.com/2005/Scion/tC/wheels/17/
Those Flik Hornets are nice for stock size rims. The +35 offset means they flush out a little more and are not so tucked in...which is cool.
If you want to cut the width difference with more "name brand" rims, there are those Falken Hanabi's. 17x7.5's at 17 lbs. each.
Old 08-29-2006 | 08:41 AM
depends what hes looking for in his wheels/tires. i personally wouldnt put 15's or 16's, ive always had 18's on my tC since i dont track or auto-x or anything like that. he sound like he wanted cheap and light, for track wheels im guessing, so i suggested some 15's or 16's since it doesnt matter how you look if youre wanting to be light and go fast and those would give you the lightest wheels. those 17x8 rims would be good if he wanted the extra traction by using a 235 or even 245 tire, but he could also get a 15x8 or 16x8. just depends on what youre goals and purposes are.
Old 08-29-2006 | 12:40 PM
JustAtC's Avatar
i heard that you also have to calibrate your speedometer when changing rims because it changes the surface area and therefore you speedometer is off.
i am a mesh kinda of guy so I like the rpm2 but kinda pricey for me.
Old 08-29-2006 | 02:09 PM
krdshrk's Avatar
You don't have to calibrate your speedo if you get the correct size wheel/tire combination. There's a plus size coversion.... stock size is 215/45R17. If you went to an 18" wheel, you'd run 215/40R18's without a problem.
Old 09-03-2006 | 10:19 PM
SpdLmtNA's Avatar
Yes, but don't forget, light wheels can also mean weak wheels. For example, a hand full of friends I know that purchased Rota's ended up breaking them on a nice pothole... not to say that will happen with all light wheels, but dont forget... there's almost always a trade off... and if there isnt a trade off, thats when you spend the big bucks. Id go for the +35 offset... enjoy... if you want to know more about rims, drop me a msg, I'll get you more info than you want ;)
Old 09-04-2006 | 02:10 AM
Yup, ive heard some horror stories about Rota's but know a lot of people that have had zero problems whatsoever. Me personally, I wouldnt go for the Rotas, because weight isn't a huge issue to me. it just always depends on the goal of what the driver wants outta his setup. It sounds like OP in later posts would rather have a cheaper wheel while HOPEFUlly being pretty light. From original post, it just sounded like he wanted a cheap/light wheel. for which I still would recommend a 16" or 15", which are typically lighter and cheaper over a 17" wheel, especially when accounting for tires. When people are looking for suggestions, (and when people are giving them), it would really help to know the person's goals.
Old 09-04-2006 | 02:43 AM
tikbhoy's Avatar
if u cant afford the rim you really want, why not invest in better tires and use the stock rim. because rims are no good if it cant grip.
lightest and cheapest is hard to come by, often u find them in cheapo cars.
Old 09-04-2006 | 03:13 AM
thisisdudewhoru's Avatar
Team Sci-Tech
http://centerlinewheels.com/sub_wheel.php?mw_id=36
Old 09-04-2006 | 03:14 AM
Team Sci-Tech
^^^Great quality. Been in the buisiness a long time and I only paid 140 a wheel for the viking model. Also I belive they do free curb repair along with repolishing.
Old 09-04-2006 | 03:32 AM
yup, its like the saying.
Your car can be: a) fast, b) cheap, c) reliable....pick two.
Old 09-07-2006 | 07:40 PM
Yoarashi's Avatar
I run the falken hanabi's on my flint mica. Just under 17 pounds for 120 a piece.
Quick Reply: lightest and cheapest rims for tC
