Lightest Wheel for the money
#41
Originally Posted by krdshrk
it's been posted... ~22 pounds
#43
It's cheaper for xA's.... smaller wheels and 4-lugs are cheaper and more common.
I stated ~22 pounds because it's the weight I've seen/heard posted the most. The ~ means give or take a bit
#44
And regarding the definition of "~", no s|-|1t, sherlock!
#45
Originally Posted by Dr_Isotope
Originally Posted by stankubrick
5zigen Fno01r-c are cheap and light...maybe you can try 16s to get lighter and cheaper.
I'll stick with my 17x8 ATech Finalspeed Erasers. 17.5lbs each. Which doesn't mean much, considering that the 245/40 rubber on it weighs 23lbs.
Ed
#46
Originally Posted by The_Instigator
Originally Posted by DuMa
the rpf1 are your best choice for money, style and weight.
I love how deep the lug pocket is..I guess thats what a +35 offset gets you
a good tip would be to do what i did. i put duct tape all around my socket and my lug keys so i wouldnt scratch the inside of that pocket everytime i needed to take off my wheel
#49
Yeah, but you need to make wider search options so we can see wheels beyond what is "recommended". There should be a way to search OZ for example and see the weights for all sizes...not just by application search. That would be a great feature that would be appreciated by a lot of users IMO.
#50
#52
i've been doing the same search for the past week or so and think i'm going to end up saving and getting quality...
in your price range i was also seriously considering the kz-s which are around 18lb
http://www.tirerack.com/wheels/Wheel...6&autoModClar=
*edit: fine i wont be lazy: 18.6 for kazera kzs
17.4 for oz ultraleggera
does anyone have experience with kazera?
#56
Originally Posted by noservice2001
i recommend centerline rpm... if anyone cares
I would get the RPMs.
I have a set on my Civic...17" at 13.x lbs each.
And they are only around $150 a rim.
www.wheelweights.net is a giant list.
#57
caters to trucks? what state are you in? i have RPMs on my xB.... they're forged, strong, cheap and effin' light... my 19s are lighter than stockies.... that's right 19s!!!! anyway, i used that website... http://www.wheelweights.net/ and that's how i heard about them.....
#59
To broaden your search, the Subaru Impreza (95-2006 non Sti) uses a 5x100 with +48 to +53 offest. Many of the Rota, OZ, etc. rims for the Subaru I think will fit the Scion, but I would call and verify. I believe the center bore diameter on the Scion is a bit smaller than the Subaru (at least that is what I experienced, I have Subaru 16" steels from a WRX on my car now for winter).
I'd also be surprised if the stock scion rims are more than 18-19 lbs. I find many of the stock manufactured rims are typically fairly light weight, and durable. I know the Subaru rims were not heavy, and very strong, so buying after market many folks put on heavier rims/tires.
I believe if you contact Kosi, they can make a K1 with any bolt pattern/offset you want, it will just be expensive. If you get Grassroots Motorsports, the tirerack ads in that magazine show many competition/lightweight wheel options.
Paul G.
Paul G.
#60
Has anyone tried these?
6061 forged A5LW 17
17x7
13.5lbs
http://www.6061forged.com/store/Product.aspx?pid=2
6061 forged AM 17
17x7
15lbs
http://www.6061forged.com/store/Product.aspx?pid=3
6061 forged A5LW 17
17x7
13.5lbs
6061 forged AM 17
17x7
15lbs
