a lil wheel help....
Old 09-29-2010 | 06:03 PM
SuShIxFiSh's Avatar
1UP Crew
Default a lil wheel help....
so i can come on one some work emotions cr-kias that are 17x9 with a offset +44 will the fit finw or will the hit also how big od a spacer would be needed?
Old 09-29-2010 | 07:20 PM
maximthegreat's Avatar
I would space 10mm front and 15mm rear.
215/40/17 all around
Old 09-29-2010 | 07:25 PM
SuShIxFiSh's Avatar
1UP Crew
So will they be tucked alot
Old 09-29-2010 | 07:56 PM
already asnwered...
Old 09-29-2010 | 09:02 PM
SuShIxFiSh's Avatar
1UP Crew
ok but how tucked will they be with out a spacer
Old 09-29-2010 | 09:16 PM
XIEmperorIX's Avatar
If I remember right (I could be wrong) but a 17x9 +44 is similar to a 17x8 +35
Old 09-29-2010 | 09:20 PM
SuShIxFiSh's Avatar
1UP Crew
^ ooooo ok so it would be basically the same then as the setup i have know but except it will be concave
Old 09-30-2010 | 01:08 AM
dropzone's Avatar
I just looked up some pics of the wheels that size and yes they are slightly concave, nothing aggressive. Now if you were to get a more proper fitting size...
17x9 +44
Old 09-30-2010 | 01:35 AM
SuShIxFiSh's Avatar
1UP Crew
But how would it be for our cars like what if I didn't run a spacer
Old 09-30-2010 | 01:59 AM
dropzone's Avatar
^I've been doing some search on that for anyone running those specs and haven't seen anything yet. The concern of the inside of the wheel hitting the suspension(it might clear, IDK) can be taken care of with a spacer as mentioned above. What result are you trying to get out of the setup? Function, flush, etc???
Old 09-30-2010 | 03:34 AM
To see if it will clear the suspension use one of the wheel/tire calculators that's stickied...it should clear though.
Old 09-30-2010 | 05:35 AM
SuShIxFiSh's Avatar
1UP Crew
I'm trying to go with the flush/stance look
Old 09-30-2010 | 06:03 AM
You're going to nee at least a 10mm spacer to be flush. According to the chart on the wheel fitment thread anyway.
Old 09-30-2010 | 07:03 AM
SuShIxFiSh's Avatar
1UP Crew
nice so then pretty much there going to be like my current works
Old 09-30-2010 | 03:17 PM
Just get them!! They will look better than your current setup. You want to go stanced? Then do a 10mm spacer in front and 15mm spacer in the rear. What is the issue?
Old 09-30-2010 | 03:38 PM
SuShIxFiSh's Avatar
1UP Crew
alright i will be picking then up on monday =D
Old 09-30-2010 | 04:02 PM
Alright! :D
Post Pics ASAP
Old 09-30-2010 | 06:39 PM
SuShIxFiSh's Avatar
1UP Crew
Alright! :D
Post Pics ASAP
Will do can't wait to get them I love my meisters but I love the concave look on the cr kias
evolving_machine
10-21-2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
EcoxA
03-18-2015 03:45 PM
GoodVibes
03-03-2015 09:47 PM
Quick Reply: a lil wheel help....
