Offset Offset Offset...
I keep asking about offset on wheels, and I thought i understood, but now I looked at the two sets of rims i'm debating between (planning to buy this week), and I dont remember, I confused my self all up. I forget what stock offset is. But the one set of wheels, the offset says +40 and the other says +45. Which one will look better? I want them to stick out further then stock if thats possible, so what would be the offset i'm looking for? Thanks guys.
Concept in Motion Crew
yes. but also make sure that the wheel width is the same or more than stock. ie if the stock wheels are 17x7. make sure the rims ur gonna buy are 17x7 or 17x7.5 or so on.
.......35 may rub depending on drop.......seems 38-42 seems to be the most comman with 7.5-8 inch wide rims.......I am going with 40s on my new rims to eliminate any problems rubbing.
You should be fine......that is like right in the middle and TRD drop is fairly high still as is my Htech drop.....18s only raise the overall tire height just so slightly like a 1/4 inch into the well.....
Originally Posted by deezangelly
Im planning on putting 17x7 on stock suspenion right now, with 40 offset. any good?
Falken Circuit Specs. 17x7 +40mm offset.
Stock Suspension:
Hotchkis Drop:
Size of the tire also effects the way it looks. I have 225/45/17 Nittos on mine.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
umnitza
09-01-2015 08:06 PM
