offset question?
offset question?
ok well im looking at a set of wheels. they are 18x8 +35 offset with 235/40/18 and im wondering if they are going to rub at all. im lowered on tein htechs, with stock struts and springs. trying to find out dont want to get them and they dont work. and i have been reading that chart. but maybe its just me i dont understand all of it. but thats why i figured i would ask. all the help is appreciated. thanks
Uhm you will probably have some rubbing, I know i have seen a few people rub with 225/40/18 when there is more than 2 people in the car. So with 235s it might be alittle worse, don't think will be excessive though
alright well that helps. the wheels are going to be new when i pick them up. im just trying to decide which tire size to go with. but it was between the 225s and the 235s. so i might 225s just to be sure. thanks for the help thought.
definitely go with 225/40.
how much you rub depends on how you drive. high speed manuvers, going over speed bumps faster than a crawling pace, packing on the pounds (passengers and/or junk in the truck) will contribute to rubbing. youre on stock shocks will makes it even easier to rub.
Re: offset question?
so let me ask one more question. wiht a 18x8 wiht 225/40 tires. what would be the best offset to go with so i dont rub on htechs and stock struts and shocks?. cause i found the same wheel in a +48 offset so im wondering if a +48 offset would be better then a +35. or if anyone can tell me what a better offset would be lmk. thanks
Deffinetly get the +35 w/ 225/40/18 tires. The front shouldn't rub. But when u get an alignment tell them to add as much negative camber as u need to not rub. It shouldn't be more than -1.5 though. What wheels are u getting btw? Jw.
well basically im thinking about these wheels here. im not really trying to spend more then im going to be spending on those. so.
http://www.discounttiredirect.com/di...271&wd=18&rw=8
they will probolly be in my picture thread. just keep a look out for killatcs picture thread i will be updating it alot in the next couple months with all the stuff i will be getting lol.
