Ordered and installed Axis Decade w/ Maxis Lip (Pics)
Originally Posted by kcheun28
the lug nuts came along with the wheels package on wheelsnext.com As for the lock, I just used the OEM ones from my OEM wheels.
Trying to replace a set of missing hub centric rings from the wheelsnext.com or should I contact wheelsnext.com about it? Also, how dangerous is it to drive without the hub centric ring?
Will this work for the decade? http://www.justforwheels.com/index.j...cat=hubcentric
Hub Centric Ring is used for aftermarket wheels that have larger center bore then the stock hub. Here is how it works according to JustForWheels.com
Here is the question, should I buy there hub centric rings from JustForWheels.com for my Axis Decade or should I call Wheelsnext.com for the rings since I never received them with my order?
"Hubcentric rings are designed to fill in the gap between the hub of the car and the center bore of the wheel. Most wheel manufacturers design their wheels with a center bore large enough to fit on most cars. Therefore, since wheel manufactures make their center bore large enough to fit most cars, most wheel fitments have a gap between the hub and the center bore. This gap usually doesn't allow for the wheel to fit hubcentric but rather lugcentric which causes vibration. Therefore, to fill the gap and ensure the fitment is hubcentric, hub rings are used."
JustForWheels.com
JustForWheels.com
