Old 06-10-2011 | 03:52 AM
  #7841
lucytheshedevil's Avatar
its throwing it cuz you dont have the tpms installed. can't get rid unless you get tpms put in
Old 06-10-2011 | 03:53 AM
  #7842
gmc_113's Avatar
its on bc your dont have the tpms sensors on the wheels
Old 06-10-2011 | 03:56 AM
  #7843
Jon's Avatar
Jon
Moderator
Moderator
^He doesn't have TPMS sensors. That wasn't introduced until 2008.
Originally Posted by Skittle
so how do i get rid of that ( ! ) symbol on the dash? car is an 05 and doesnt have TPMS but its throwing bc of wheel size im guessing....just 2.5 inches wider then factory TRD wheels....what gives?
You have to recalibrate the sensor. It uses rotational mass I believe to determine if one of your tires is low on pressure. And since you changed the wheels, of course it's gonna come on. There's instructions on resetting it in the owner's manual.
Old 06-10-2011 | 04:24 AM
  #7844
Spoony's Avatar
'07, actually. I just learn to live with it.
I heard it can be disabled completely, though.
Old 06-10-2011 | 04:43 AM
  #7845
dropzone's Avatar
Disagree on the year introduced, 2007 was the first year of TPMS on the tC, I had a Spec package and was even on the 16" steelies.
6/10 - EDIT: TPMS sensors on the wheels started with the '07.
Old 06-10-2011 | 05:25 AM
  #7846
Jon's Avatar
Jon
Moderator
Moderator
My mistake. Either way, he doesn't have them.
Old 06-10-2011 | 12:45 PM
  #7847
you can turn off the light with the button in the glove box but it will prob come back on.
Old 06-10-2011 | 02:52 PM
  #7848
Jon's Avatar
Jon
Moderator
Moderator
If you reset it properly it won't come back on. It will calibrate to the new wheel/tire set up.
Old 06-10-2011 | 05:21 PM
  #7849
Skittle's Avatar
thanks Jon for your insight. Those other people just weren't reading my previous post correctly I guess lol. The car didn't come with a Owner's manual though, is there a site, or page you can refer me to in order to completely disable it properly?
Old 06-10-2011 | 05:31 PM
  #7850
Jon's Avatar
Jon
Moderator
Moderator
I didn't feel like going outside to get my manual, but I found these steps online.
The tire pressure monitor detects any changes in the tire inflation pressure. Therefore, it must initialize and store it in its memory if the tires or wheels have been replaced or the tires have been rotated. you can re-initialize the system by following these steps:
1) Check and make sure that your tires are inflated to the correct pressure.
2) Turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (in the glove box) until the warning light turns off and then release the switch.
3) Now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
4) Initialization is *not* completed until driving at the vehicle speed of 19mph or over for more than one hour. the tire pressure monitoring starts when initialization is completed.
Old 06-10-2011 | 07:04 PM
  #7851
mrhat's Avatar
my 06 has them.
Old 06-10-2011 | 07:47 PM
  #7852
Jon's Avatar
Jon
Moderator
Moderator
I have a 06 and mine doesn't. According to this it shouldn't: https://www.scionlife.com/forums/scion-tc-1g-wheel-tire-1646/read-before-you-change-wheels-2007-tc-68883/
Old 06-10-2011 | 08:45 PM
  #7853
Irishguy0224's Avatar
My TMPS light just came back on after being off for like 4 months... Stupid aftermarket wheels lol
Old 06-10-2011 | 10:25 PM
  #7854
Jasper Ash's Avatar
deleted this pic. Just didn't like it.
Old 06-10-2011 | 10:38 PM
  #7855
mrhat's Avatar
jon the little exclamation mark that shows up if your tire is low?
Old 06-10-2011 | 11:43 PM
  #7856
Spoony's Avatar
I think the argument is when did the TPMS sensors (that are attached to the valve stem) come out on the tC.
Old 06-11-2011 | 12:32 AM
  #7857
Jon's Avatar
Jon
Moderator
Moderator
Everyone has the light, but how the car gets the info is different. In the 05-06 it's measured through the ABS system by sensing differences in rotational speed. In the 07+, there are 4 modules mounted on each valve stem on the wheels inside the tires.
Old 06-11-2011 | 07:27 AM
  #7858
mrhat's Avatar
oh. I failed. I will now leave the thread.
Old 06-13-2011 | 05:56 AM
  #7859
tC-S08's Avatar
If I have 6-7 turns on my extended ICHIBA wheel stud after installing 10mm spacers am I good or how many turns am I suppose to have to b safe?
Old 06-14-2011 | 08:28 AM
  #7860
INFKT's Avatar
Were ur aftermarket extended studs meant for 10mm spacers?
Im running stock studs with an 8mm..n i prolly have less turns than you..i think u shud be alright.
Quick Reply: Req: Aggressive wheel stance pics
