#9861
^255/35 18. Gotta be a 18x12 if stretched. Will be watching to see how this turns out. Is the wheel true 5x100 or running adapters? If it's adapters it's not going to look as impressive as a true 5x100 setup.
#9862
Interesting for sure. I think the highest offset we can run on a 10" wheel is +30. To keep the inner clearance the same if it's a 12" it would have to be +5 offset. That also adds 50mm more wheel on the outside.
#9864
Do you know how much inner clearance you have by chance? I may put together a table with highest offset possible from 8-12" wheels. If someone has like 2mm or so of inner clearance post up.
#9865
While we're on the topic, my wheels are coming off today and I don't feel like making any suspension adjustments as I'll only be on stock wheels for a couple days.. Will OEM wheels clear everything at -4* Camber in the rear?
#9872
I use mine when im not at my buddies, normally it's the only thing that fits under there unless i remember to put my car on 2x4s
#9873
scissor jack it is until i find something low-profile... someone buy my wheeels!
https://www.scionlife.com/forums/sho...ight=bbs+rc090
#9875
Yeah probably 1 inch pull and -8* camber. I was going to relip my old wheels to 18x12 et 10 but I sold them. I'm doing negative offsets instead on my new 18x10 all around setup. It should poke about the same as 18x12 et 17. The downside of running 12s is it will actually raise your car. But yeah, we'll see.
#9876
http://www.harborfreight.com/rapid-p...html-7814.html 89.99
thats a 1.5 ton compact alumin rapid pump low profile, they go up to 3ton, and you can fit it under anything...I have one and it works great, the only issue is that i think it only jacks up to 14"s or so...
shipping is a flatrate of 6.99 i think. and they have coupons like 10% off so, yeah you can get cheap tools for daily use.
#9880
Getting rid of my 18x9.5 dpts and getting some xxr 526 17x9 today going back to 17s cuz I like the ride better lookin foward to changin up the look there hyper black but I'm thinkin about this crazy idea to polish the face what do u guys think? 8th set of wheels in less than 3 years this is bad ;)
Sidekick 4G
Sidekick 4G
