Old 02-20-2010 | 01:45 AM
  #1701
dqlostsoulz's Avatar
^^Helps
Old 02-20-2010 | 01:57 AM
  #1702
chicotunner07's Avatar
Originally Posted by chicotunner07
^so does negative camber get rid of the tire/fender hitting issue?
taking notes for future setup, lol
so this risk never goes away? even with wide wheels and stretched tires?
Old 02-20-2010 | 01:59 AM
  #1703
Ask jaewrek he is putting it to the limit. I have to be very cautious on turns and drive ways..things of that nature.
Old 02-20-2010 | 02:18 AM
  #1704
jaewrek's Avatar
My only advice is keep your wheels straight whenever you go over something that pushes your suspension up. Driveways, speed bumps, turns with random ___ bumps.
Every time my fenders dented in was after going up a drive way.
I think stiffer springs would help, because your suspension wouldn't travel as much.
I'd assume camber would help. I don't know cause I don't have any =(
But I also thought it might make things worse if the wheel is cambered in, when you take sharp turns I think the upper rear portion of the tire would stick out more during a turn than if it wasn't cambered in. *shrug*
Old 02-20-2010 | 04:24 PM
  #1705
Aroddalobster's Avatar
you guys do know there's more to it than just camber, right? caster can also be changed so that when you turn, your wheels camber in. if suspension travel is an issue, just stick in a spring spacer. or get air cups lawl
Old 02-20-2010 | 04:57 PM
  #1706
rrimportracer's Avatar
Air cups?
Old 02-20-2010 | 05:10 PM
  #1707
No I did not..how is that achieved??
Old 02-20-2010 | 05:16 PM
  #1708
Ya, I've been looking up how to adjust caster, no luck care to elaborate?
Old 02-20-2010 | 06:21 PM
  #1709
aircup:
http://www.youtube.com/watch?v=upGAjGXPA54
Basically little air bags that go on top of coilovers so you can get air ride adjustability and coilover performance. they cost just as much as airbags... so yeah, probably not something for scions.
caster:
To give you a visual example, look at the front of this
That's hella caster right there. I'm sure you can guess that a car's steering angle is a lot more perpendicular to the ground than that. I suck at explaining things, so
http://www.240edge.com/performance/tuning-caster.html
wikipedia does wonders, btw.
if you want to adjust it, i would definitely say go to an alignment shop. Just like adjusting camber and toe on stock bolts/arms, It's not an easy task, and i'm not even sure if it's possible to adjust all too much on our cars.
Old 02-20-2010 | 08:22 PM
  #1710
^i know what caster is, but im sure there is no caster adjustability on our tc's
Old 02-20-2010 | 08:58 PM
  #1711
davedavetC's Avatar
Caster is not adjustable on the tC that I know of
Old 02-21-2010 | 12:51 AM
  #1712
t_urbo_C_harged's Avatar
if you have coilovers with adjustable pillow mounts then you can.
Old 02-21-2010 | 04:31 AM
  #1713
davedavetC's Avatar
adjustable pillow mounts allow camber adjustment, i havent seen one yet with caster.
Old 02-21-2010 | 05:24 AM
  #1714
jaewrek's Avatar
what if you mount the top hat so it adjusts it front and back instead of left and right? lol
Old 02-21-2010 | 06:36 AM
  #1715
Old 02-21-2010 | 12:50 PM
  #1716
davedavetC's Avatar
some wont do that, and then you lose camber adjustments. plus im not sure if that will even work.
Old 02-21-2010 | 02:33 PM
  #1717
you can do that. That was what I was referring too. Then get ingalls camber bolts for the front. Best of both worlds I currently have this kit on each side running a little over -2* of camber (had to do this since the HKS coils don't have adjustable pillow mounts).
http://www.dezod.com/pd_ingalls_engi...r_kittc_05.cfm
This guy did this a while back I believe.
https://www.scionlife.com/forums/sho...ight=275+tires
Old 02-21-2010 | 03:32 PM
  #1718
didnt even think about that, but yes hes right! although its only gonna be a max of 2 inches i think and i dont think that would fix the issue..
im just gonna be as careful as possible,lol
Old 02-22-2010 | 12:42 AM
  #1719
Kanchi's Avatar
I believe the rears have factory caster adjustment. Its the bolt on the chassis side of the rear camber arms.
*Edited* my bad I meant toe lol
Old 02-22-2010 | 02:27 AM
  #1720
davedavetC's Avatar
thats camber. i know for a fact there isnt caster adjustment for the rear
Quick Reply: Req: Aggressive wheel stance pics
