Space between fender and tire
Ok when i buy my 18" Rims im going to have low pros and i have Ground Control coilovers if i leave the coilovers set teh way they are is it still going to LOOK lower because of the differnet size wheel?
Originally Posted by 2redgerm6
getting bigger wheels will not get rid of wheel gap. you will still need to lower your car.
Yea man thats why im gonna save up and later on buy the coil springs for a 2 inch drop it will look alot better i think these tc's come with a huge fender gap dont you think?
look at this diagram:
the "overall diameter" is the "section height" of the tire (the sidewall height) plus the "rim diameter". when you use an 18" wheel, the tires mounted on them have a "section height" (or sidewall height) that is smaller than when using a 17" wheel. the total height of the wheel and tire is nearly the same regardless of the rim size.
this is why some "racers" opt to use lightweight 15" or 16" wheels because rubber and air weighs less than metal. their section height (sidewall) is taller.
buying bigger diameter wheels will not close the wheel gap, you will just have shorter sidewall tires. you need shorter springs or coil overs.
mischadoll
03-09-2015 05:48 AM
