Tire Damage Concern
Tire Damage Concern
http://www.flickr.com/photos/5100101...n/photostream/
Here are the pictures. I'm wondering if a tire change is necessary. I got this about 2-3 hours ago while I was taking a right at an intersection. I hit a red curb. There aren't any dents on the rim, just a lot of scratches. What are your thoughts?
Thanks in advance.
Thanks in advance.
http://www.flickr.com/photos/51001013@N07/4806351897/
Sorry, I don't know why the link changed.
Thanks in advance.
Thanks in advance.
Ouch man. I had some sidewall shred off once but it was only the top rubber layer and my uncles shop said just to cut it off to prevent it from wanting to peel. Yours on the other hand is pretty bad.
Location: Living in the Omaha, NE area, traveling all over the continent
That's bad, and should be replaced, but it's not really an emergency repair situation. You can probably drive on that for a while as long as you take it easy through the curves and corners, and keep your speed down. However, if you do drive on it make sure you check it every time for any bulging anywhere on the sidewall. If it starts bulging at all, or if you feel any vibration start while you're driving then make sure you stop immediately and get it replaced, as that probably means the tire is about to blow. Don't get me wrong, driving on it at all is a risk, but unless it gets worse it's a fairly low chance.
I wouldn't worry about it. I assume you hit a curb. This happened to my girl and we continued to drive on her tires for 1500 or less more miles. We eventually swapped the tires because she needed a change (30000+ miles on Yoko S3) but the tires ran fine.
Oh but do change the tires when you get the money but if you don't have the fundings at this moment, just take it easy.
fur_pig
03-20-2020 04:28 PM
Fisqual
09-22-2015 05:51 AM
viciouzgamer
02-18-2015 03:26 PM
fur_pig
12-05-2014 12:48 PM
