Tire Pressure light will not stay off
Again....it detects a difference in rotation speed in one tire vs. the others. it doesn't give a rat's "you know what" about the pressure in the tires (wudda ya think it's a lexus...j/k).
it merely detects a difference in pressure between the four. it's looking for a flat.
inflate them to whatever you're comfortable with but make sure you fill them within 4 psi of each other to be safe. (same in front two, same in rear two) then hold button in gb til light goes out and drive for an hour or so.
mines always on no matter what i do. i took it to the dealer and they checked the pressure for me and adjusted it. 3 days later, the light came back on again. at this point, i dont even care, i ignore it
Originally Posted by t6c9
the only way the light will stay off is if you have the tires at 32 front, 29 rear... the computer knows. if you have different size wheels on the car, then i dunno how it would work right, you'd probably have to have the dealer reset it for your new wheels, but looks like you have the stock's right? just try setting them 32 front, 29 rear, then holding the tire pressure button till it flashes, then turn the key off and then start the car and it should go away.
i had the same problem where my PSI was correct but i was reseting the meter the incorrect way.
http://home.cfl.rr.com/icdedppl/faq.html#c15
1. Turn key to the "On" position.
2. Press and hold the Tire pressure reset untill the light disappears.
3. Press and hold the tire pressure light again untill it blinks 3 times
4. Initialization is *not* completed until driving at the vehicle speed of 19 mph or over for more than one hour. the tire pressure monitoring starts when initialization is completed.
Hope that helps you guys out
Originally Posted by gcxandy
Let me know if that solves your problem.
Thanks
Maybe I should try that. My tire pressure light keeps coming on too. I went to Shell and pumped up my tires twice already...I think the pressure for each tire is different now. I'm going to take it to the dealer tomorrow so they can adjust the pressure correctly for all the wheels. I may have pumped different amounts of air into each of the tires.
Hey, do I just take it to the dealership or do I have to make an appointment?
just follow the directions in your owners manual for the tire pressure warning light reset.
theres also a way to reset/recalibrate the ecu by using the odometer **** (also resets you "maintainance required" light after oil change")
I seriously hope that's a joke. if not, then reach in your pocket and take out your keys, find the big fat gray one with the buttons on it, and drop it in a padded envelope. I'll pm you my address, because you don't deserve to own a car.
Originally Posted by TongMan
where can I get a psi checker?
but don't go in asking for a "psi checker" or they'll laugh at you too! say it with me now: tire...pressure...guage.
seriously. SOrry man. But that was pretty hilarious. I love Getcaughtdead's quote about mailing in the key. haha, thats pretty close to accurate.
Take this time sitting in front of your computer to google info about cars/mechanics/engineering/etc.. It will help you out a lot.
Besides just ignoring the light.... and covering it over with a small piece of tape... is there a way to reset it NOT to come on? I doubt it, but figured i'd ask anyhow
I've been to discound tire and even the freakin dealer to get this fixed and it just wont go away, keeps coming back within minutes of reset. I guess it's just one of those absurdly annoying lights that wont go away like the abs light was in my integra.
omg....
FIX: See the little tire reset button in your glove compartment? it will be your best friend.
With TPM Lite on:
-push reset button in until the TPM Light flashes and goes off.
-release button for 1 second, then push it back in and continue to hold for about 10 seconds (just to be safe).
-release button
your done. TPM Light shouldn't come on anymore untill u reset ecu (disconnect battery) or push the button again to reactivate.
i used to have the same recurring issue, this seems to have worked for me.
With TPM Lite on:
-release button
