wheel and tires size for my tc...?
Old 02-10-2005 | 03:16 AM
LucidBD's Avatar
Default wheel and tires size for my tc...?
ok so i need to know if these will fit on tC with 1"- 1.5" drop....anyone? this setup is Staggered.
19"X8.5", 37 offset, 19"X9.5", 37 offset, 5X112 bolt pattern.
Old 02-10-2005 | 01:50 PM
LucidBD's Avatar
anyone...BUMP
Old 02-10-2005 | 03:01 PM
VIP_tC's Avatar
should fit ok except wrong bolt pattern - you need 5X100... Although I havent seen that exact offset, although I know a 35 front and 40 rear work in those sizes.
Old 02-10-2005 | 06:43 PM
RogerTTR's Avatar
FYI, our fitment team recommends 19X8, 5-100, ET45. An offset of 37mm may be a little aggressive, as well as the 9.5" rear. Also, as pointed out, you are going to need a 5-100 bolt pattern!
Old 02-10-2005 | 08:18 PM
JDMJim's Avatar
I squeezed a +30 front and rear on to my wifes tC. THe wheels weren't mine, they were just a check.
Old 02-11-2005 | 01:28 AM
LucidBD's Avatar
ok so 19"x8", 35 offset, 19"x8", 35 offset 5X100 should be ok with the 1-1.5" drop?
Old 08-23-2006 | 04:56 AM
r0cky1nyc's Avatar
would you be able to put 19x8.5 on the front
and 19x9.5 on the back
and if so what size tires would you go with
Old 08-23-2006 | 08:44 AM
Chapman's Avatar
That's fine. I have the same setup and I rub a lil bit only (need to shave more fender). I have no wheel gap front and back so that's why I'm rubbing. Also running stretched 215/35/19 falkens.
Old 08-24-2006 | 06:00 PM
nodnarb's Avatar
I have 19x8.5 with a 45 offset and tire size are 225/35 and no rubbing whatsoever
scionlife
371
06-02-2015 11:00 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
12-29-2014 11:39 PM
JM Auto Racing
12-19-2014 06:36 PM
foxSCION
13
12-03-2003 05:40 AM
scioninla
10-30-2003 08:01 PM
Quick Reply: wheel and tires size for my tc...?
