Wheels rubbing with TRD Springs
Old 05-20-2009 | 08:46 PM
take4roll10's Avatar
Default Wheels rubbing with TRD Springs
Everyone kept telling me this setup would not have any rubbing issues, but mine seem to do.
I have TRD springs (one years old), 18x8 35 offset rims. Kumho ASX tires 225/40/18
and I hear a rubbing sound from the rear tires when going over large dips or bumps. Even with no one sitting in the backseats. is those going to cause any damage? Is there a reason why this is happening when everyone else doesn't have this problem
thanks!
Old 05-20-2009 | 10:19 PM
Checho's Avatar
not really, your rubbing should be minimal on those TRD's since the drop isn't really dramatic at all.
Old 05-20-2009 | 10:26 PM
Uyles's Avatar
I have 18"s with TRD's and I don't rub at all.
That's odd.
However, I'm hoping to drop the tC on coils soon so that'll change.
Old 05-20-2009 | 10:29 PM
TheQuietThings's Avatar
You shouldnt have any problems. I was rubbing with Hotchkis springs for over a year and a half and I was fine.
Old 05-20-2009 | 10:56 PM
yea i'm going to have to get the struts checked out. because everyone i know with TRDs and 18's don't rub.
Old 05-20-2009 | 11:37 PM
TRDIZZLE's Avatar
When I had trd springs I was at a two finger gap with my 18s and never rubber even with a packed car
Old 05-20-2009 | 11:46 PM
captainlaziness's Avatar
^^Yeah, I routinely pick up ~400lbs of product for my restaurant and I don't rub. TRD springs and struts with 18x8 et37.
Old 05-20-2009 | 11:50 PM
yea that's why its so weird to me that it's rubbing and the front is actually lower and that doesn't rub. I only have 27k miles on the car. isn't that a little early for struts to go?
Old 05-21-2009 | 06:13 AM
Hyghgynx's Avatar
Default Re: Wheels rubbing with TRD Springs
Originally Posted by take4roll10
I have TRD springs (one years old), 18x8 35 offset rims. Kumho ASX tires 225/40/18.
I have the EXACT set up (albeit FIVEaxis rims) and I don't rub at all. Have you had it aligned yet?
Old 05-21-2009 | 07:26 AM
ScionTEK's Avatar
I guess I should chime in with my experience to level out the field.
I had TRDs before, and I had 18" 7.5 width wheels with 23 effective offset on AST Kumhos (225/40) WITH a 10" JL W7 sub in a custom ported box. With this combination I did get minor rubbing in the rear going over dips in the road while driving and also on steep entry ways when going at an angle. I'm sure you only rub when the car "dips" other wise on smooth roads it should be fine is what I'm understanding.
When I changed to F&F Type II Coilovers (current) I lowered the rear to zero to half finger (my TRDs in the rear were half finger gap due to subwoofer) in the rear and set them on full stiffness. It still exhibited rubbing on dips and steep driveways, but not as bad as with the TRDs since the coils are stiffer.
BUT, I recently got new tires (my kumho ast were bald) and switched to Falken Ziex 329 (same 225/40) and my rubbing went away. Even when I drive fast over dips it doesnt rub, and when I reverse out of my steep driveway it doesnt rub either (used to rub all the time before the tire change)
I then saw that the Kumho AST sidewall was straight and full sitting flush with the rim of the wheel, BUT the Falken Ziex's sidewall was angled in which has the characteristics of a stretched tire (without the stretch as i said before they are still 225/40). With the angled sidewall of the Falkens it helped move the top of the tire inside the well avoiding the fender lip.
When considering rubbing issues i think it's a good idea to consider all parts of the equation. Wheel size, width, offset, Tire width, series, diameter, as well as anomalies such as passengers and extra weight in the trunk.
You have to have the right combination inorder to rub on TRDs since it's a pretty modest drop (but it is defiantely possible). Some people have wide wheels but stretched tires but nothing in the trunk and no passengers which is why they don't rub. Some people may have narrow high offset wheels fat tires and extra weight in the trunk and still don't rub. The list goes on and on.
The ASX sidewall is pretty much the same as the AST (my brother had ASX on his eclipse) So I think if you switched to an "angled" sidewall tire like the Falken Ziex it may possibly help get rid of the Rubbing.
Of course as I said before it's good to consider all aspects as well as strange anomalies, such as strut construction/life (installation, but it's hard to mess up installation since it is pretty straight forward and goes in one way) and such or alignment. But you've driven on it for 27k and other than the rubbing you havent indicate anything problems with the car or suspension in general other than rubbing.
So in my opinion, and from my experience it's probably due to the sidewall of your tire, getting a more angled ("stretch-like") tire would probably help. Also the front doesn't really rub because the fender lip is actually Slightly rolled from factory whereas the rear is L-Shaped.
I hoped this help, I know I wrote alot but I'm just trying to cover all the bases and share my experience. Hopefully I didn't leave anything out, but good luck on getting it fixed. I know when I was rubbing it annoyed the heck outta me, so I can understand the frustration even though I was on TRDs at the time.
Old 05-21-2009 | 07:30 AM
SCIONtific_tC's Avatar
i have 18x8.5 with 38 offset and i rub on the rear. tires are 225/40/18
Old 05-21-2009 | 07:33 AM
ScionTEK's Avatar
I see you have Neo Gens SCIONtific_tC. Are the sidewalls straight flush and full with the rim? or angled?
Also SCIONtific_tC I see that you have a custom box sub set up in the trunk which probably attributes to the weight on the springs lowering it a bit. I forgot to add that I had done measurements with my sub out of the car and in the car, and saw about Half an Inch (more or less) difference in height. I made a mistake in not mentioning this in the TRD rear sag thread debate.
Also forgot to mention take4roll10 you won't have any cosmetic damages from minor rubbing, and your tires should be fine (other than being a little mangled on the edge) Since I had my AST tires from new to bald while rubbing and they were fine, and my fenders didn't show any damage. But this is only for Minor rubbing.
Old 05-21-2009 | 12:56 PM
ScionJim23's Avatar
I'm surprised you have rubbing issues. I'm on 18x8 wheels with over a 2'' drop on coils with no rub.
Old 05-21-2009 | 02:01 PM
I am very surprised too. smooth roads and going over dips at low speeds, its fine, but big dips, it rubs.
i'm going to get my shocks checked next week. my car is 4 years. 27K miles, so maybe they're blown.
Old 05-21-2009 | 02:35 PM
ooh i havent updated my profile in a while but i have new rims and tires. i have falken grbs and they're pretty flush with the rim. also i have the ed sub which isn't really that heavy.
Old 05-21-2009 | 03:52 PM
ScionJim23's Avatar
that could be a possibility that you have a bad shock which is causing the rub.
DJ_FroZone
25
05-30-2019 07:17 PM
JPuehl
01-10-2015 01:01 AM
kleecker
12-31-2014 09:42 AM
minter66
12-15-2014 01:45 PM
GreatWhitexA
11
12-23-2003 05:25 AM
Quick Reply: Wheels rubbing with TRD Springs
