When it rains i hear a scrapingn noise from my brakes.
I have a little shreiking nose that comes on every now and then when it rains... I asked my dad about this and he said it was just probably brake dust and dirt making the noise. I've been fine ever since. I've had my car since Oct. 04'.
i had this car since december 2005.
it sounds like 2 peices of metal grinding into each other.
but it sounds fine after i cruise around town for a couple of minutes.
since it isn't consistent, i'm guessing your dad is right.
I get a scraping noise when it rains and my car sits for a while. But it goes away after I brake a couple of times. I did notice a little rust on my rotors prior to driving it. I always thought it was the rust getting scrapped off.
go check your rotors
if you see deep grooves on it then you need pads
or after it rains your rotors gets a lil rusty (Normal)
and when you first use them it will sound like its grinding
but definately check your rotors for deep grooves
i have this same noise, after its wet and when first driving. it goes away. I'm at about 3.25k miles so I don't think its the brakes being out....... I will check though.....
ya know my ABS has never felt the need to activate before. and I just took the wickedest 90 degree batman turn last night......
actually my truck does the same thing too, it goes away. its not the ABS, for me anyway, My truck goes ABS at the slightest provocation, so I know its not the ABS kicking in on my tC........
i have had to slam on my breaks a few times before and my ABS has never felt the need to kick on....
