Will 2011 tC wheels fit on 08' tC?
I found a good deal on some 11' tC wheels and was considering putting them on my 08' tC. I know the 04-10' use a 5-100 lug and the 11'+ are using 5-114.3s. Does anyone know if they will still fit on my 08' without having to use an adapter? I found a few wheels that say 5-100/5-114.3 for the lugs. Not sure what I should do.
Thanks
Thanks
You are probably talking about a set of aftermarket rims that are dual drilled to fit both lug patterns. This means it has 10 holes drilled around the center hub opening. (5 holes to fit 114, and 5 for 100). The stock '11 rims are drilled to only fit the 114 pattern (5 lug holes), just as your stock 08 rims are drilled only to fit the 100(5 lug holes). I think your best bet would be adapters.
DaBlackBox
134
04-10-2022 02:04 PM
BrokenTC2
01-27-2015 03:32 AM
kingofthecrate
01-21-2015 09:28 PM
