Will snow/salt harm the alloy wheels?
If there are ANY scratches, nicks, abrasions, no matter how small, that go through to the metal, there will most likely be corrosion.
If the wheels are not coated, there will be corrosion.
Bare metal portions of the wheel - mounting surfaces and such - will corrode.
Basically, running "utility wheels" in salt season makes sense if you want to save your alloys.
In areas that don't have the salt problem, the problem is no where near as bad.
Tom
Tom
Originally Posted by Jiggaman
i used my stock wheels for the winter, all you have to do is clean your car like once a week like i did and you wont have any problems.
Big Sky Scion
well depending on where you live, you should have some places where you feed quarters in the machine and it will let you power wash you own car, and its covered so you dont have to worry about the snow(i live in f'ing montana, we have nothing here, so you should definately have something like this)
just make sure you dry everything real nice so it wont freeze!
worst comes to worst, get that shovel out and hand wash those beasts :D
In winter I run mine through a 'no-touch' automated car wash that has high pressure underbody and wheel sprays (and uses heated water...).
I've never had a problem with underbody or wheel corrosion, but then again, we don't have a salt season here like they do in your area...
Tom
Tom
yeah I suppose I'll probably end up using both of what was recommended. We do have the "quarter" car wash places, and I'll probably do the power underwash automated one on occasion as well (Delta Sonic here). Thanks guys.
Originally Posted by snarcher
mabey after 12 years....
but just buy some cheap steel rims and wrap them in 45$ snows, well worth it in the long run
Mine scratched up pretty badly during a freezing rain storm that turned all the snow into ice.
Since snow plows doesn't go through my neighborhood...I had no choice but to drive through thick ice and scratch the crap out of them.
of the car.
airmankevin1
02-14-2018 01:23 PM
