Will these fit my tc!
Old 10-04-2006 | 04:06 AM
1_kLEan_tC's Avatar
Default Will these fit my tc!
hey i need some help...will these rims fit my tc with a hotchiks drop on it...
17X7.5 Offset: 48mm Bolt pattern 5X100![/b]
Old 10-04-2006 | 04:10 AM
lj973gm's Avatar
yes they will but they will tuck in a little more than stock not what you want to do when buying new wheels.
Keep the offset around 35mm and you will look good and clear your drop.
You can run those no problem stock offset if 45mm those are 48mm just look crappy like stock. Wheels spacers are a option
Old 11-07-2006 | 10:13 AM
Deathwish238's Avatar
Why will 48mm look crappy like stock?
Old 11-07-2006 | 06:23 PM
jaggedjeremy's Avatar
it won't look horrible at all. it's only 3mm so sure it'll tuck in more, but it's not TOO much. you'll be fine man. go for it.
Old 11-07-2006 | 11:56 PM
If anything I think it could look nicer.
Old 11-09-2006 | 05:14 PM
LargeORangeFont's Avatar
It will be out 3mm more than stock. This is because the wheel you have chosen is WIDER than stock. The width of the wheel will effect the offset. most people fail to realize that.
Here is a good tool for calculating offset.
http://www.1010tires.com/WheelOffsetCalculator.asp
Ashley
Old 11-09-2006 | 07:10 PM
Originally Posted by LargeORangeFont
It will be out 3mm more than stock. This is because the wheel you have chosen is WIDER than stock. The width of the wheel will effect the offset. most people fali to realize that.
Ashley
hmm. i guess i failed.
Old 11-09-2006 | 07:18 PM
Neothin's Avatar
i have 18x7.5 w/ 48mm offset.
check my diy thread to see how tucked in the wheels will look
https://www.scionlife.com/forums/viewtopic.php?t=147154
SpaceCaptain
05-11-2015 06:24 PM
KTamAK187
04-15-2015 10:08 PM
HotLavaDestiny
04-10-2015 05:10 PM
skruff
04-06-2015 06:34 PM
Quick Reply: Will these fit my tc!
