Winter tires I ended up going with
Here's what I ended up going with:
(4) Yokohama
195/60R-15 88R BW
Ice Guard IG20
2003 TOYOTA COROLLA CE SEDAN
$74.00 $296.00
(4) MB Wheels
15X6.5 5-100/11438SM
Five X
$74.00 $296.00
(1)
Wheel Installation Kit
for MB Wheels Five X
$45.00 $45.00
(1)
Free Hub Centric Rings
$0.00 $0.00
(4)
Valve Stems
$3.00 $12.00
UPS Ground FREE
TOTAL $649.00
Figured I spend $40 to upgrade to wheels instead of the steelies. Any final thoughts? If something doesn't work, I'll have to call in before the morning EST.
Thanks to everyone who helped!
(4) Yokohama
195/60R-15 88R BW
Ice Guard IG20
$74.00 $296.00
(4) MB Wheels
Five X
$74.00 $296.00
(1)
$45.00 $45.00
(1)
$0.00 $0.00
(4)
Valve Stems
$3.00 $12.00
UPS Ground FREE
TOTAL $649.00
I have steelies , 205/60QR-15 and with the Blizzak's the are the same size as the stock tires. After 2 winters the steel looks like ____ and the salt and sand sticks to the inside of the rim and goes off balance.
also check http://www.tirerack.com/snow/WinterP...9&autoModClar= they can help with wheel and tire sizing.
Update"
What is the offset I need for the tC? The lady I talked to at a tire store said 4", is that right? How about any of these?
http://pittsburgh.craigslist.org/pts/905997662.html
Acura TL
http://pittsburgh.craigslist.org/pts/903143259.html
Bmw 3 series
http://pittsburgh.craigslist.org/pts/902274743.html
95 cavalier
http://pittsburgh.craigslist.org/pts/899271572.html
BMW x5
http://pittsburgh.craigslist.org/pts/898802243.html
http://pittsburgh.craigslist.org/pts/895477364.html
bmw e46
http://pittsburgh.craigslist.org/pts/895028321.html
I'm buying them this Friday so any help is appreciated!
Acura TL
Bmw 3 series
95 cavalier
BMW x5
bmw e46
The only ones that woulkd work with your bolt pattern is the '95 Cavalier, but your back ate the problem that some 15's do not clear tC brakes. All the other ones listed will not fit because they have the wrong bolt pattern.
I heard corolla wheels fit Scion tc's, so I searched using Corolla specs at Tirerack and was wondering if these 15" rims would work:
http://www.tirerack.com/wheels/Wheel...All&sort=Price
Will all corolla wheels fit basically?
(getting that 15" rim above will still allow me to use like $60 cheap tire changes in both winter/summer tires since it's a more common wheel, right?)
They might work, but you are still risking the fact that they might not clear your brakes. From my understanding our calipers are slightly bigger than the Corolla's. Someone please let me know if I'm wrong.
well as long as they fit... i just got SUPER lucky and found a set...
http://pittsburgh.craigslist.org/pts/907268297.html
Wintermark Radial HT P185/65 R15 snow tires
Let me know within the next 8 hours because I'm going to go pick them up I think.
cid_mcdp
01-05-2015 02:45 PM
toyotaisme
13
11-14-2003 01:37 PM
