Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
5k HID lighting help
Old 01-03-2013 | 04:30 AM
kenguyen's Avatar
Default 5k HID lighting help
Im currently running on 5k 35w hids from ddmtuning.
Its really hard to see any light on rainy days and even some clear nights.
If I get the relay harness, will this make the output any brighter? any other remedies? or should i just invest in a better kit (mengmotorsports, etc)?
Old 01-03-2013 | 04:39 AM
Diffraction's Avatar
That's strange. I have 8000k 35w and they are plenty bright even for night time rainy days. i ran it with and without a relay harness and i couldn't tell a difference in brightness.
Old 01-03-2013 | 05:12 AM
kenguyen's Avatar
Yeah its really hard to notice the light and its getting really irritating. The only time i can REALLY notice it is on unlighted roads.
but then again, i think i may have my bulbs pointed too high so i may try pointing lower if that helps at all.
Old 01-03-2013 | 06:19 AM
izzy209's Avatar
i belive i read somewhere that lights with hint of blue are harder to see in the rain due to them reflecting off the water driplets. same with fog. the more the yelow the better the visibilty in rain. im planning on getting fogs with low k rating to get the yellow look.
Old 01-03-2013 | 06:21 AM
kenguyen's Avatar
The only hint of blue I get is during the warmup.
Other than that, its straight up white.
but its starting to dim so it looks bluer.
Old 01-03-2013 | 06:27 AM
perhaps your ballasts are dying
Old 01-03-2013 | 07:39 AM
izzy209's Avatar
Don't know about op but mine are new. Cool colored hid's are just hard to see in rain. And as far as seeing in the city I would upgrade to 55watt kit
Old 01-03-2013 | 01:19 PM
Thermos2003's Avatar
I had the same problem. 35 watt HIDs were dimmer than stock bulbs. I replaced them with 55 watt 5000K HIDs from HID Extra with a relay harness just in case. Zero problems and they are a noticeable and classy improvement over stock.
Old 01-03-2013 | 05:32 PM
kenguyen's Avatar
Thanks guys
Ive decided to orderba 55w 5k or 6k and cross my fingers it works
Old 01-05-2013 | 01:05 AM
BeAlLsTaR13's Avatar
ive got 5000k ddm 33w kit in the low beams and never had an issues, rain yea because light reflects off the road but any other time its bright as all hell
Old 01-06-2013 | 06:55 AM
Archangel1183's Avatar
I had a 55W 4500K ddm Kit in my XA but recently switched the out for a 35W. The light was reflecting off an odd part on my headlight and blinding people/drivers on the left and right. I decided to go a bit dimmer to be nice. I can definitely tell the difference though. Like you mentioned, on bright streets, I can barely see the light on the floor.
Proper adjustment also plays a huge role in lighting.
Old 01-08-2013 | 05:56 PM
biglilsteve's Avatar
If the kit isn't defective, this isn't true at all...
OEM HIDs for luxury brands are all 35w.
Old 01-09-2013 | 07:04 PM
That may be the case with OEM. I was driving around for a week with 35 watt 5000k HIDs and in the rain I couldn't see. Could be the color difference but I had better visibility with stock bulbs over a 35 watt kit. My 55 watt kit on the other hand is far brighter than stock.
GoodVibes
03-10-2015 05:29 AM
scsteven
01-25-2015 02:06 AM
tc_Jake
12-31-2014 02:45 AM
jaspercanda
12-28-2014 11:09 AM
umnitza
12-01-2014 07:26 PM
Quick Reply: 5k HID lighting help
