Crazy Bright Flexible LED Strips
So I totally stole this DRL idea from someone else on here, but the flexible LED strips I've found so far just aren't very bright and it's obviously hard to know how bright the LEDs online really are.
So anyone know of 12" flexible LED strips that are very bright? Front or side mount will work as long as the front mount strip is the normal width.
Thanks
Thanks
i was seriously look up the same thing! haha i went back to the forum to try and look for the original guy that did it and found this!
if i find anything i'll let u know...or if u find something let me know
side topic: how are u wiring them by the way? always on? or w/ headlights? or w/parking lights?
I just got one from ijdmtoy (they have several types of LED strips and LED DRLs) and will tap to corner lights wires that way it will turn on, on parking lights/corners and headlights. Very easy to install. I did one on my last car.
Thanks
Thanks
I have mine setup to be on any time the car is on. I tapped power off the MAF sensor. The right way to do it is to go into the cabin and get power off a fuse there.
And oznium has front mount flex LEDs for about $30 for a pair, but not sure how bright they really are...
@ BlackCloudz these lights use 3M tape, and above the top of your headlight housing is a little lip that they fit into/behind, and shine through perfectly. I am working on my DIY were I explain how to hook it up to the fuse box. Its almost done and on the way....stay tuned!
Full amatuer DIY posted in a new thread with pics! I know I would certainly like to find some that are brighter though.
@ nolakpd504 You cant use the factory fuse in the addacircuit, you have to use the common mini fuses. It does the same job though.
@ colinantherus: I am no expert, but from what I have read, the higher the amps that go through the wire, the more heat = greater chance of wires melting? From what I understand, higher amps will not make the LED brighter, will it? I use a 3amp because I read that a 12 inch strip will only pull about 1.4 amps, and I have 2 strips, and thus, my fuse will pop in the event that a surge happens, instead of frying my wires/causing a fire.....
@ nolakpd504: Thats wierd man, mine worked first try every try. I must have plugged it in and out 30+ times with a problem. Now you got me nervous like its gonna fall out...lol. maybe try very gently and gradually bending the post? or return and exchange it.
@druidiron i used a larger fuse because the 10 or 15 amp fuse that was being used by the parking lights wouldnt be able to handle the lights being spliced in. all it does is allow for more electricity to be used. ive had my "audi style lights" on my headlights for around a month and a half and the wires are still in perfect condition
another option
Check this site out, if they are anything like the pic, should be pretty bright!
http://www.carid.com/2011-scion-tc-x...kit-92558.html
