Plastidip front lip
how to plasti dip (anything)
mask off a square around the area to be painted (this will prevent overspray...the kind thats hard to get off)
spray a single coat...(just one time left to right)..and YES, paint will get onto the body, but no big deal
wait about 15 minutes
repeat until you get about 3-5 coats (the more coats, the thicker, the easier to peel off later) waiting 15 minutes inbetween
(optional) spray a clear coat
wait 15 minutes
remove the newspaper/tape or whatever u used to mask the square
use your fingers to peel the (dry) paint off the body/areas you dont want painted
NOTE: IF you want to put a coat of regular spray paint (in a different color)...i strongly suggest 5 or more coats before applying the regular spray paint...and then an optional clear coat after
NOTE: on your first spray, its okay that there is still some silver of the emblem still showing...as you add coats it will even out and fill with the color of the plasti dip
NOTE: YOU DO NOT HAVE TO REMOVE ANYTHING OFF THE CAR
wait 15 minutes
wait 15 minutes
wait 15 minutes
Pj, love your car man. When you did the front did you mask off the whole grill with tape? And how did you mask around the back bumper so nicely? You didn't use a razor knife right? I also have a suggestion for your car.. plastidip eyelids. Super easy and make the car look angry!
but for the back i used tape just like the front. I just spent a good 30 minutes making sure every piece of tape was straight and that the curves were perfect.
and for the front all i did was push back the grill (the sides and bottom snap off) and then it was easier to ape the bottom lip... but yeah i put newspaper over the grill and the whole front of the car so it was less excess to take off after.
viciouzgamer
02-18-2015 04:26 PM
ExtremeDimensions
12-18-2014 05:47 PM
umnitza
12-01-2014 07:26 PM
